Originally Posted by
Billman
Been getting a few emails from this so I thought I would update.
Fluidampr & Injectors are gone...
Here's what's left
GM Crank Pulley – 12557345 $91
GM Crankshaft Position Sensor -- 12557046 $46
Transmission Shifter Cable -- 15037353 $56
Delco Water Pump -- 251-590 $174
Delco Fan Clutch – 15022302 $85
GM Hood Release Cable -- 15769412 $37
GM Windshield Wiper Circuit Board -- 12463090 $66
GM Multifunction Switch -- 26100985 $253
GM Ignition Switch – 26061330 $156
GM Tail Lights – 5977867 & 5977868 $121(2)
Multiple sets of Tail Light Circuit Boards
Moog Inner Tie Rods -- ES2837RL $32(2)
Moog Outer Tie Rods -- ES2836RL $31(2)
Moog Tie Rod Sleeves -- ES2004S $9(2)
Moog Pitman Arm -- K6335 $35
Moog Idler Arm -- K6447 $52
Moog Idler Arm Bracket -- K6532 $56
GM Universal Joints – 88964413 $67(2)
Delco Glow Plugs – 60g $72
A/C Accumulator – 15-1739 $20
Front Brake Pads -- Napa CMX-7339
Rear Brake Shoes -- 452
2 -- Wheel Cylinders
Napa Steering Wheel Position Sensor
Used Cipa Towing Mirrors Slip-on
are the taillights OEM or aftermarket sexy ones? was the truck a 4x4? could use all the front end pieces if it is a 2wd... i think that several of the pieces are the same....
1993 sierra 3500 drw, 6.5L DB2831 ground spring, 4000rpm, custom cold air intake, H1C, 3 inch magna flow stainless muffler, remote tranny & engine oil coolers with fans.
