Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: New Member, Old Truck
  1. #21
    It doesn't freeze in Texas? I thought everywhere there did. I lived in Fort Worth for 3 years and enjoyed watching people that had no clue driving on ice. That and watching them crack up listening to KPLEX and the Hiney Wine commercials or Little Susy and her Car Aerobics.
    Yes cracks in the block or heads. I had a 383 once that I sold to a guy and I told him to test it first. He got it all bolted in his pickup and started to fill with fluids and they started running everywhere.
  2. #22
    Sep 2008
    SE Texas
    Dallas and North Texas are a different environment than SE Texas (Houston area but more coastal). It does, on occasion, reach 31.9 deg F here and pandemonium breaks out. But overall, it really doesn't freeze, and if we do get a light freeze, it doesn't last but for a few hours.
    The engine has always had anti-freeze in it, even if it's old. The anti-freeze that we got out didn't look nearly as bad as I thought it should have.
    I bought the book advertised by this site. I'm hoping it will arrive this week.
    We took the radiator to a shop in Houston but he said it would cost $600 to recore it so we bought a new aluminum one for $350. We are saving the original just in case we ever decided to get it restored.
  3. #23
    Sep 2008
    SE Texas
    So far we’ve got all the accessories out ( water pump, alternator, AC compressor, radiator, etc). Pulled the fuel tank last night. The lines from the fuel tank to the low pressure fuel pump are a mixture of steel and rubber. Going to clear those and change all the rubber.
  4. #24
    Sep 2008
    SE Texas
    Also we’re putting in a new fuel tank/filler hoses and hardware.
  5. #25
    Sep 2008
    SE Texas
    I found the plug to the block heater zip tied in its factory storage condition. Radiator is here too.
    A previous reply said it was a 16 gallon tank does anybody know if that’s right?
  6. #26
    Sep 2008
    SE Texas
    All 8 glow plugs successfully removed! Water pump installed.
  7. #27
    Sep 2008
    SE Texas
    Sprayed a little mystery oil into the glow plug holes. Waited a few days and then turned the motor over by hand. Fuel tank is here but we have not received the new straps and bolt up hardware. We have replaced all the fuel lines that were rubber up to the fuel pump (except one piece that we will tackle soon).
    We do have a new fuel filter, but I thought I read that there were two filters?
    I thought the fuel system went like this: Tank-->Mechanical Pump-->fuel filter-->injector pump-->injectors-->return line-->fuel tank. The fuel lines get a little fuzzy at the back of the engine an I can't quite see where they go exactly but now maybe I think they go to the firewall filter first? Is that right? Where is the 2nd filter?
  8. #28
    1983 models had 2 filters in OEM trim. Tank --> Primary --> Lift pump --> Secondary --> IP.
    If you have only one in the system, it's probably OK, especially if it's a later, more efficient type, and installed between the lift pump and injection pump. It has a simple job, and only has to do it. You can also upgrade any OEM filters to modern aftermarket (such as Racor) that uses more common (and much less expensive) filter elements, as well as some being more helpful with priming (some have pumps, which goes a long way to help the starting system). I regularly recommend this, as the OEM filters and parts are becoming more and more rare and costly. Even a Duramax filter would be a good option, compared to the original. Filter elements aren't cheap, but they are very effective and you can find them anywhere. It also has a priming pump, as well as a heater. You may be able to find the assembly in a wreck for cheap.
  9. #29
    Sep 2008
    SE Texas
    Which is the filter on the firewall? Primary or secondary?
    I'm a little confused on the fuel lines. After it leaves the fuel tank I traced them to the back of the engine compartment at which point they kind of snake around the block and I can't really see where they go exactly and they also cross with the other fuel lines. But it almost looks like it goes to the firewall filter then to the mechanical fuel pump. I haven't really gotten under there and looked real hard just looking from the top and wiggling the lines. Regardless the fuel lines are attached to the mechanical pump.
  10. #30
    Apr 2016
    Sarasota
    On my old van there was a filter mounted below the cab, before the mechanical pump and then a 2nd one on top of the engine behind the intake manifold between the mechanical lift pump and the injector pump. The mounting locations will be different on a truck compared to my van, but if you have two, there should be a filter before and after the mechanical lift pump. If it only has one filter (either OEM or a conversion) it would be between the lift pump and the injector pump. My current van has an aftermarket Racor behind the manifold, between the lift and injector pumps. It is nice because it has a primer and made pumping up my fuel system after replacing my head a simple process. I recommend it as a very useful modification.
  11. #31
    Sep 2008
    SE Texas
    Got a P/N for the Racor filter with a pump on it?
  12. #32
    Sep 2008
    SE Texas
    Fuel tank installed finally. What a PITA.
    Replaced all fuel lines up to the injector pump.
    We spun the motor over with the gp out to see if we could get fuel to the ip. We disconnected the wire from the ip solenoid. We didn’t think about the oil cooler lines and after about 2-3 attempts had oil all over the floor. We will put a loop in the line today and try again.
  13. #33
    Quote Originally Posted by TheGoose View Post
    You need 12V to the solenoid or it will remain closed
  14. #34
    Sep 2008
    SE Texas
    Danged if the motor didn't fire right up. Ran it about 20 seconds or so. Now re-connecting all the accessories and radiator parts.
    Q: What is the best coolant to use for this engine?
  15. #35
    Good quality green stuff
