Results 1 to 2 of 2
Thread: my 90 dually swap
    May 2020
    Pierron Il.
    Default my 90 dually swap
    Just about ready to fire up 6.2 swap in my 90 dually it originally had 454 gas, using wire that fed HEI coil to feed inj. pump and cold start advance and high idle solenoid running power thru temp sender on rear of right head, but which one i have one on the side behind injector and one on top of head at rear of intake or does it make any difference? i'll post some pics if i every figure out how,lol
    One of the switches is a simple thermal switch that switches when the engine reaches about 95 degrees F. The other sender is variable resistor with a positive temperature coefficient (changes resistance with engine temp).
    The HPCA/High Idle solenoid (Housing Pressure Cold Advance) uses the former and the engine temperature gauge uses the latter.
  1. my 90 dually swap
    By 90 dually in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 10-24-2020, 19:37
  2. Dually SRW swap
    By Wing Nut OOA in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 06-19-2009, 13:11
  3. Dually Wheel Swap
    By DTR2214 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 09-17-2008, 15:52
  4. Duramax swap into 86 dually
    By Dick Wagner in forum Duramax Diesel Performance Shop
    Last Post: 07-22-2004, 07:21
  5. Dually swap
    By NH2112 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-14-2003, 20:14
