Results 1 to 20 of 29
Thread: MAX. TOWING CAPACITY - Suburban 2500; 4x4, 6.5L Turbo Diesel
    Aug 2007
    Sacramento, California
    Default MAX. TOWING CAPACITY - Suburban 2500; 4x4, 6.5L Turbo Diesel
    Would anyone out there know the MAX. Towing Capacity of my 1996 Suburban, 2500, 4x4, 6.5L Turbo Diesel?????
    When towing my 9,000 lbs Travel Trailer up a hill, the truck slows down to about 30 mpH and there does not seem to be any "juice" left in her? The truck has the 4.10 Gear ratio.
    Am I towing too much? What can be done in order to improve the power?
    I just recently installed a aFe stage 2 Performance Air Intake Kit which helps a lot already in regards to power, I will install a 4" Exhaust system next. Will that help or does anyone have any suggestions how I can improve the power while towing any further?
    Thanks in advance.
    '96 Chevy Suburban LT 2500, 4x4, 6.5L Turbo Diesel, 4.10 Rear, 175K miles
    *** Towing 26' ft. Travel Trailer (6,165 lbs DRY) ***
    - aFe Stage 2 Performance Air Intake Kit
    - 4" inch Jerry Jardine, PINNACLE POWER EXHAUST, 5" inch Chrome Tip
    - 2-1/2" inch Crossover Pipe, mandrel bent
    - KENNEDY remote mounted PMD/FSD Cooler Package, DTech PMD
    - AUTOMETER Triple Gauge Pillar (Boost, EGT/Pyro, Trans. Temp.)
    - HEATH Turbo-Master
    - HEATH Max-E-Tork PCM
    - PRODIGY Brake Controller
    - BILSTEIN Shocks
    - Forged WELD RACING Rims
    - 265x75 R16 BF GOODRICH All-Terrain T/A's
    Dec 2002
    Terre Haute IN
    Gauges first, what was your Boost/Exhaust Temp/Engine Temp at the top of the hill? Does your 96 have dual thermostats?
    If so:
    1. Clean the radiator. All kinds of junk will be stuck between it and the AC condenser.
    2. Exhaust, bigger the better, loose the soot trap if they don't inspect in your area.
    3. Intercooler. Apparently Peninsular has a front mount almost ready. Kennedy and others have one that mounts under the front skid plate.
    4. Reflash your ECM, this can add ~50HP.
    If you don't have dual thermos add that between 1 and 2. Performance injectors are completely worthless IMO.
    99 K2500 GMC Ext Cab, 6.5TD, Heath ECM reflash, TDC Offset -1.80, Bumped Optic, FSD Isolator, Turbo Master, KD 3.5" Exhaust, 4.10s and 33x11.50, Intercooler is next.
    98 Burb 350 1/2T/4l60/246/10Bolts - Wifes Ride
    80 Olds Cutlass 6.2/Studded/700R4/12Bolt 3.30s/IP=4544 Juiced by JK/Best MPG=30
    79 Olds Cutlass, 410ci/700R4 - Currently Restoring
    1992 Mitsubishi Eclipse Turbo, currently 12PSI max boost
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Email= Dr.Diesel@gmail.com WA9SDJ
    Aug 2007
    Thanks Andy.
    Could you be a bit more specifc regarding Item 4, flashing the ECM Module? (I assume ECM stands for Engine Control Module?) What needs to be done, what is the cost?
    In regards to the radiator, do you mean flush it or disassemble it and clean the outside?
    Do you think my truck should easily tow my trailer or am I pushing it????
    Thanks.
    - BILSTEIN Shocks
    Quote Originally Posted by Jochen Woern View Post
    Thanks Andy.
    Yes that would be a reflash or an exchange
    Inside and out would be better, outside at minimum
    Thanks.
    It should.
    May 2000
    Little Neck,NY,USA
    According to GM's 1996 trailering data in the GMC Yukon/Suburban sales brochure, you are overweight for the diesel package.
    2500 series with the 6.5 diesel and 3.73 gears and 4wd has a max trailering weight of 6000 lbs and tongue weight of 750 lbs.
    With 4.10 gears and 4wd the max trailering weight is 7500 lbs and 900 lbs tongue weight.
    If you had the 7.4 gas motor with 4wd and 3.73, the max trailering weight would be 8000 lbs and 900 lbs tongue weight, with 4.10 gears the max trailering weight is 10,000 lbs with a tongue weight of 1000 lbs.
    William
    97 Chevy Tahoe 2Dr 6.5 Kennedy Exhaust Pipes w/Homemade Resonator and Flowmaster Muffler, Turbo Tech intercooler and Kennedy/Westers computer
    01 Sunline 2363 Travel Trailer
    Aug 2007
    Ok Guys, now help me out here: I see some of you guys with 6.5, 1 ton Dually's all over this website and you guys are pulling way more trailer than I ever will. I would assume that the 6.5 engine is identical regardless if in a 1 ton dually or a two door Tahoe? YES??? NO???
    I think what some of you guys are pulling out there by looking at some of the pics must be in the range of 10,000 - 12,000 lbs dry weight at least?
    Are you saying I must purchase a 7.4L Gas engine in order to pull my trailer? I do not like gas engines and unfortunately can not afford a new Duramax. AND, I really do not want want to have to go and buy an Excursion with a 7.3Powerstroke.
    Any help here would be greatly appreciated.
    - BILSTEIN Shocks
    Dec 2002
    Terre Haute IN
    First we need to confirm your truck is performaning the way it should stock. Clean area in-front of the radiator, fuel/air filters and sustained boost?
    You didn't say what the grade was when you were pulling, but 9000lbs on a stock 6.5 is pushing it if say it was 7% for a mile heading through West Virginia!
    A properly equiped 6.5 will handle 9000lbs no problem.
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2007
    Hello again Andy.
    As far as I can tell, area in front of the radiator is very clean, air filter is a brand new aFe Stage 2 Air Intake Performance Kit, not sure about the fuel filter though.
    Not sure how to measure the boost, I have no gauges that would possibly tell me this.
    I was going up a pretty steep grade and definitely for more than a mile. However, not sure how many % of a grade. The truck at that point got pretty hot, it has the bigger waterpump with dual thermostats as well.
    So, if I read between the lines, it seems that everyone out there is telling me that my Burb will not pull all this unless I modify it extensively?
    - BILSTEIN Shocks
    As has already been mentioned, Gauges, cooling, exhaust and a ECM upgrade. (Lower temp fan clutch) get that fan on as soon as you can.
    The issue with the weight is also related to the Burb being able to tow ownly off a rear hitch.
    The weight of the trailer in this situation should not exceed the tow vehicle weight. (To be safe) Now I will tell you straight out that these rigs will do far more but the safety issue should be foremost on ones mind.
    The DaHoooley's are mostly reefin on 5th wheels and the weight issue is a whole different story then.
    You should be able to handle your trailer fairly well after the upgrades, just make sure of the brakes on the trailer and keep safety in mind.
    Robyn
    Dec 2002
    Terre Haute IN
    Any noticable black smoke from the tail pipe at full throttle? If the condition of the fuel filter is unknown replace it anyhow, then every 10K miles.
    It is very easy to hit defueling on a 6.5. You could have only been makeing 100HP by 1/2 way up the hill! Increasing boost with either a ECM reflash or a mechanical spring, adding an Intercooler will allow you to maintain power pretty much indenfiantly!
    ECM reflash = more boost and more fuel, $500
    Intercooler = $1500 for a prepackaged kit, or 1/3 of that for a ebay DIY.
    Adding both and you'd likely maintain 60+ MPH up that same grade.
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2007
    Thanks Robyn.
    Should I keep my confidence in my rig based on your comments? Braking is no issue at all, trailer is brand new with excellent brakes. The only issue is power going up hill.
    OK Andy, back to you (and forgive me please, maybe some of my questions seem a bit odd to you but I am trying to gain my knowledge here as I go):
    - My truck does not smoke at all, not when cold, not when hot, not at idle not at full throttle, there is no difference if I tow or if I am running empty.
    - Can I replace the fuel filter myself or is it fairly difficult? Where exactly is it located? Do you know what the cost of the filter is and what the GM Dealer would charge for the exchange?
    - What is considered "defueling"? Not enough diesel flowing through the engine due to a clogged filter???
    - Could you describe the ECM flash in detail? What do I need to do, where can this be done? Or do I buy a part (Chip) to replace the ECM with? Where is the ECM located?
    - What will the Intercooler do for me, how does it work?
    Again, MANY THANKS for your help, I greatly appreciate it.
    I just do not really want to sell my rig, the truck looks awesome, (Two tone white and gold, with the nice rims and the BF Goodrich All-Terrains, Chrome Nerf/Step Bars) other then towing runs awseome and the interior is in top shape, not even the drivers seat is worn out/split like on so many other trucks of this year.
    - BILSTEIN Shocks
    Mar 2007
    Woodstock GA
    Hello again Andy.
    If you didn't take the top portion of the shroud off and look in between the A/C and radiator i'd bet there's junk in there. That's where the leaves..etc accumulate and block the air flow. The enhanced clutch/fan combo with the duramax blades will help as well. A 3" downpipe in place of the factory crushed one should be looked into also. My radiator looked clean, but when i took it out it wasn't and had about 3" of leaves..crud at the bottom between it and the A/C area. Several vendors also sell 180 deg thermostats, the above stuff and a good flush helped my heat situation out a lot.
    Good luck.
    Don
    Dec 2002
    Terre Haute IN
    No problem on the questions.
    The fuel filter is super easy to change, it will also give you a chance to check the lift pump. Do a search here, you'll find the info needed to complete it.
    Defueling means the computer is pulling back fuel to try and save the engine from a melt down. With no intercooler these engines can reach intake temps of almost 300 degrees in a very short time. The computer pulls fuel when the coolant or intake temps get to high.
    I'm with daustin, I found all kinds of crap jammed in the bottom of mine I couldn't see before I took it apart.
    Is pulling the main purpose for your Burb? How many miles on the engine?
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2007
    Thanks Andy.
    - What about the ECM Flash?
    - I guess I will have to take that radiator shroud apart this weekend and see what's going on in there.
    Pulling is definitely NOT the main purpose for the BURB, it is used as a daily driver and family rig. However, when pulling with the family on a camp trip, it is somewhat nerve recking when the darn thing is getting hot and it does not want to go up the hill as fast as I think it possibly should.
    The engine has not quite 166,000 (165,8_ _) on it.
    - BILSTEIN Shocks
    Dec 2002
    Terre Haute IN
    The reflash will add 15-20mm3 of fuel, probably ~40HP, but also cause you to hit defueling just that much faster!
    Oh yea, 9000lbs travel trailer? What is that a 32'er!?
    Don't give up on your Burb, you'll have a hard time finding a nicer vehicle IMO.
    With 166K i'd probably start with this:
    1. Serious radiator cleaning
    2. Change out both thermostats, most install the 180s. Get these from kennedydiesel.com to make sure your getting the correct ones.
    3. New fuel filter.
    4. Gauges! Gauges! and more Gauges! You need to confirm your vacuum actuated wastegate is working, this is what controls your turbo boost.
    5. Exhaust.
    6. Reflash/Intercooler.
    And if that doesn't work, sell it to me cheap!
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2007
    Thanks Andy.
    Well, the travel trailer is only a 26' er but it has a super slide on it. The dry weight on it is 6,165 lbs, add 45 gallons of water (8.33 lbs/gallon = 374.85 lbs) and you are now looking at 6,540 lbs.
    Add all the things you load in a trailer, all the stuff you take for the kids PLUS all the Beer, I am thinking I should be close to 9K lbs.
    OK, so:
    - I have the air intake kit on it already
    - will change the exhaust system to a 4" JARADINE soon.
    - the raditor will get cleaned with no problem, thanks for the input.
    - fuel filter changed
    - Wll the thermostats make a big difference and why? Are the original factory ones a problem? What is the cost at Kennedy?
    However, the gauges will cause me some problems since I have no clue how to install this. How else can you confirm the wastegate is working???
    Looks like I have a lot of work ahead of me,................
    And HOW CHEAP is cheap??????????
    - BILSTEIN Shocks
    Dec 2002
    Terre Haute IN
    Good call, I'd forgotten about the required stash of beer!
    166K is about the usefull life for a set of thermostats. IIRC they are like $12 each from Kennedy.
    If your not a big wrencher, drive down to the local cruise strip, find the guy blowing the most black smoke out of his tail pipe, and pay him $75 to install your gauges!!! A good set will run you about $220, Kennedy has a pile of these as well.
    With a fresh fuel filter (assuming your lift pump is working) you should not be blowing hardly any black smoke. If your not, your probably making the factory boost numbers.
    ECM reflash, about $500, intercooler about $1500.
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    Aug 2007
    Thanks for all your help Andy!
    - BILSTEIN Shocks
    Dec 2002
    Terre Haute IN
    No problem, keep us posted as to your progress..
    39 Chevy Rat Rod
    2004 Sportsman 600
    2002 Scrambler 500
    2007 Sportsman 90
    2003 Kazuma 50
    2001 XR50
    1990 Murry 46"
    43 Total pistons!
    NC
    jochen,
    I had about the same results you have when I first bought my 96 extended cab new. I first chaged out the very restrictive exhaust system and put a turbo boost and Exhaust temp gauge on it. I then bought a Manual Turbo master waste gate control from Heath diesel. I later got his reflas of the ECM done. It's a whole different truck now. I would have installed a intercooler but I have what they call a light duty 2500 (6 lug wheels) and the frame is a little narrower so I can't install the normal intercooler that most install.\
    I do have the dual thermopstat crossover (late 96) and 3.73 gears that were stock on the truck.
    I also did a minor adjustment to the spring on the radiator fan clutch to make it come in at 200 deg instead of 220.
    I pull a 7200lb (dry) bumper hitch type camper up some pretty steep mountains here in NC with no problem. It will get a little warm if I try to run them at 65 so I back it off a little. I origanally could only get about 25 going up Black mountain near Ashville.
    I also pull a 8500lb boat which runs out to around 11k with the tripple axle trailer and don't have any problems on the interstates here in NC. I don't climb mountains though.
    96 6.5 ext cab C2500 short bed, 2 IP rep. under warranty. Came with Dual Thermostats & HO water pump,Tweaked fan clutch engages @200, Kennedy exhaust, Heath Turbo Boost, Heath ECM
    John Deere Tractor (It likes cetane improvers also)diesel65j@netscape.net (not always monitored)
