Results 1 to 7 of 7
Thread: The '99 Burb cranks, smokes, no start
    Mar 2004
    ATL
    Default The '99 Burb cranks, smokes, no start
    Hello everyone
    After sitting for about four weeks since the last stranding episode I stared tinkering with the Burb. She'll crank at starting speed, build about 30 psi oil pressure, almost fire, but not start.
    So far, have done the following:
    2 new batteries
    New Stanadyne gray PMD from Kennedy
    Cleaned filter manager
    Replaced and bled new GM filter
    Checked flow at IP inlet, good fuel no bubbles
    Glow seems good, I can watch the voltmeter cycle with the key at on
    Attempted start with optical sensor disconnected
    Cracked open injector lines 1, 2, 3, 5, 6, and 7...fuel at each of those cylinders. (Can't reach 4 and 8)
    It ran until I parked at long term parking for about 8 days, then would crank but not start. It feels closer to starting now, it'll buck and catch for a few seconds but not run, it has gotten to around 500rpm while trying and coughing. Gray smoke at tailpipe.
    Any suggestions?
    Thanks!
    Buzz
    '99 K2500 'Burb, my DD
    301K
    K&N insert in stock airbox
    Relocated PMD behind front bumper
    Brighton, CO, USA
    Default Resistor in new FSD?
    Does your new gray FSD from Kennedy have a resistor in the connector cavity? My friend just went through this on his 98. His truck would start but run very roughly, like it was missing on more than one cylinder. He installed the resistor from his old FSD, and now it runs great with the gray one. Just a thought. Joe.
    2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
    1996 Chevy C2500 6.5 auto Ext. Cab LB
    Mar 2004
    ATL
    Joe -
    Yep, I bought a new #5 from JK when I got the PMD. Have been working my way down the troubleshooting guide in the GM manual, will have some updates to the story shortly...
    Thanks for the suggestion!
    Buzz
    301K
    Dec 2009
    In the North
    Things that have caught me before,.
    After installing new batteries glow plugs only cycle for a second or two until there has been an attempt to start.
    Relay for glow plugs has stuck on an fried glow plugs,.
    Stepper motor has given up on the ip and won't give enough timing to start nicely,.
    In you case i would pull the 2-3 easy glow plugs on drivers side and use booster cables to verify they are heating up.
    Try plugging it in too,. See if it will fire then go from there
    1999 chev suburban C2500
    300,000 mi
    Mar 2004
    ATL
    She's alive!! Turns out it was a bad female end on the 4-pin harness from the IP to the PCM. Went back to troubleshooting 101...had glow for sure, air as well, but no fuel. I mucked around with that pigtail connection while cranking and it coughed, almost started. Unplugged, forced the leads a bit further into the connector, re-connected and bang she fired. Found a replacement female end at connectorexpertsdotcom, whom I recommend. There site has a million parts, but of you send photos of either end you need they will match it if they have it. Two FedEx days later I was driving the old beast again.
    Buzz
    301K
    Outstanding!
    Feb 2014
    NC
    Congrats.
    1995 K3500 CCLB 6.5 turbo diesel
  1. 1992 P30 Chassis Van cranks but will not start
    By JerryOwen in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-01-2016, 10:35
  2. 99 burb stall and no start
    By Judotrip in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-18-2015, 09:43
  3. No Start - No guages - Cranks Strong
    By jerry598 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-18-2005, 12:32
  4. CRANKS BUT NO START
    By BERT in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-05-2005, 20:16
  5. CRANKS BUT NO START
    Last Post: 11-23-2004, 20:39
