Results 1 to 6 of 6
Thread: Electrical trouble with my 6.5
    Aug 2014
    USA, Lizton, Indiana
    Default Electrical trouble with my 6.5
    Hey y'all I'm new on here and I really need some help with my 6.5. I have a 98 6.5 turbo Silverado and I don't have any power coming off the other side of my glow plug relay. sometimes the truck starts up and then it'll die and I wont have anything. None of my wait to start lights come on or any dash lights will come on but I have power to my radio and headlights will come on if I turn them on. Could it be in the ignition switch? Has anyone else had this issue?
    Nov 2000
    magnolia tx
    Default RE electrical trouble
    Good morning. Just a thought try checking your battery cable terminals the side post terms can be a pita sometimes. I chased a problem like yours for weeks. I cleaned the, then used jumper cables to both batteries. (Make sure positive to positive negative to negative) I'm sure the experts will chime in here soon. I hope this helps. Walt
    walt
    Ignition switch is a likely suspect.
    Missy
    Jan 2005
    Denville,New Jersey
    Cleaning the battery terminals is always a good 1'st move,then clean the grounds off of the intake manifold paying close attention to the passenger side on the last bolt..... keep us posted on your results. A lot of us here have had the same problem, at one time or another. Oh i almost forgot,clean the negative battery wires on both sides of the intake also!
    Aug 2010
    Missy
    Often the cause.
    x2
    2005 Chev K3500 CCLB
    Feb 2003
    Grand Rapids MN 55744
    Ignition switch
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
