Thread: Could it just be old fuel
    Jan 2020
    Michigan
    Default Could it just be old fuel
    So I have a 98 k2500 with 186k ip went bad end of 2016 put a new one in got the timing good enough to start it next day went to start it to take it to a mechanic and time it no go, every glow plug broke off in the head, then life happened pushed it out of the shop and bought another truck .... fast forward 3 years started working on it again put new plugs it the fsd was new mid 2016. It’s all back together now, and it will crank but won’t even act like it’s going to start. Pulled 4 plugs drivers side and have fuel mist but no start. Could it just be old fuel?
    Not likely
    Make sure the glow plugs are getting hot.
    Does the glow lamp come on and then go off after a bit????
    Which plugs did you put in...60G ????
    If you have fuel mist it means the IP is working.
    Fuel with some heat and it should fire up....
    DO NOT BE TEMPTED TO USE ETHER
    Make sure the glow system is working.
    Good luck
    Jan 2020
    Michigan
    I went with the Bosch this time and can se the volt meter dipping quite a bit when I hear the relay clicking what’s the best way to see if there getting hot ?
    Pull one out and ground the body and then turn the key on.
    They should glow nice and red....
    To be safe..use a jumper cable and clamp if to the metal "wrench flats" and then connect the cable to a good engine ground.
    Plug in the block heater to get some extra heat into the engine.
  1. New rebuild #4 misfire
    By Ooowillow in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-15-2014, 14:02
  2. Water in Diesel fuel
    By mwool in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-06-2012, 16:46
  3. fishbiting IP fuel metering questions and observations
    By Hubert in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-18-2008, 19:07
  4. What fuel additive, if any?
    By Geo in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-08-2003, 10:27
  5. Bad fuel - watch out! (long)
    By Steve StLaurent in forum General Diesel
    Last Post: 06-29-2001, 20:35
