Results 1 to 2 of 2
Thread: OBD2 won't work with '94 truck
    Jun 2020
    Seattle
    Default OBD2 won't work with '94 truck
    I have a 1994 C3500 TD that has the OBD1 connector under the dashboard. My very trusty OBD2 scanner won't fit the OBD1 so I bought a converter cable that on one end has the OBD1 and the other has the OBD2. There is no response to the scanner because it looks like only 2 terminals on my truck's connector are even hooked up. Is there supposed to be any PO_ _ _
    type codes offered in 1994? I do get the paperclip treatment to show a
    DTC 36 but no other method to possibly display the PO_ _ _ style codes. What scanner can display PO codes from an OBD1 output connector, if any?
    OBD I DTC's are 2 digit. The 5 digit codes started with OBD II, 1996+. If you're only getting a DTC 36, then that's all there is.
    If you only have 2 wires connected to your ALDL port, then you will have to power your scanner externally if you want bi-directional communication. Any non-CA Emission model 3500 with manual transmission has no need for all the other stuff that would normally be connected on other models or smog region.
  1. My D/A truck moved overnight!?!?!?
    By Quack_Addict in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 03-25-2011, 13:22
  2. VIN check and build sheet (pretty please)
    By LyndaSuzan in forum Duramax 6600
    Last Post: 02-23-2011, 08:11
  3. ADVICE! engine swap or new truck?
    By Kmehr in forum General Diesel
    Last Post: 10-14-2010, 09:50
  4. Replies: 9
    Last Post: 10-19-2004, 13:28
  5. Replies: 50
    Last Post: 08-22-2003, 09:15
