Results 1 to 7 of 7
Thread: Help me Identify Part Name
    Jun 2020
    Spokane
    Default Help me Identify Part Name
    Will someone please help me identify the name of the coolant hose in the attached image.
    The hose comes off the Thermostat Housing and connects to the bulkhead. I know it is a coolant hose because I have a leak in it and coolant is coming out. There is a leak where the hose connects to the Thermostat Housing.
    I doubt I am able to replace the threaded connector that connects it to the Thermostat Housing, so I assume I have to replace the entire hose.
    Can the connector be replaced or do I need to replace the entire hose?
    What is the name of the hose so I can purchase the correct part?
    Thank you.
    Dec 2005
    Klamath falls/keno Oregon
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Jun 2020
    Spokane
    Sorry for lame post without engine details
    1996 6.5 Diesel, no modifications
    Jun 2020
    Spokane
    ANSWER: HVAC Heater Hose and the connector is called the Heater Hose Connector
    HVAC Heater Hose: AC Delco Part # 15998368
    Heater Hose Connector Part # 88891735 at 1A Auto
    It's a common part that can be found at any chain parts store for cheap, usually in stock. Do yourself a favor and replace it with a brass or stainless barbed nipple and hose clamps. The OEM "Quick Connect" part is convenient only during assembly. Not much use for them after that.
    Jun 2020
    Spokane
    Thank you SpongeBob for pointing me in the right direction.
    And DmaxMaverick for great advice
    Case in point...
    Just tonight, I helped my son replace the water outlet on his 2016 Cruze 1.4T (original has a crack, but at 62K, no biggie). The replacement part included a hose nipple for the air bleed line. The original looked just fine, so we reused it instead of replacing it with the included part. Job complete, and all's well. Well, except the original quick connect bleed line connection. It's seeping a bit of coolant. We'll replace the nipple this weekend.
  1. front driveshaft part #
    By matuva in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-28-2007, 00:44
  2. Help Me Identify this Part - Please
    By mcmonroe in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-14-2005, 14:13
  3. Interior Part # help
    By ratlover in forum 2500HD/3500 Accessories
    Last Post: 09-16-2003, 08:18
  4. OEM Mirror/Armrest part numbers?
    By MNR in forum 2500HD/3500 Accessories
    Last Post: 08-01-2002, 20:54
