Results 1 to 6 of 6
Thread: DIY - Injector Pump Replacement
    Jun 2020
    Spokane
    Default DIY - Injector Pump Replacement
    OK, I have decided to do it. After watching several YouTube videos, and reading some of the posts on here I am going for it. I do have one question, is it a good idea to replace the injectors at the same time? That is an additional $300 i would rather not spend, but if it necessary?
    A little background information might be helpful.
    At least check the pop pressures and spray pattern
    You SHOULD have all the injectors POP pressures very close to one another.
    If you have any that are really low and peeing a stream rather than giving a nice cone of mist this is not good.
    Getting a good set of squirts in the engine can make a world of difference in STARTING and overall operation.
    Have fun....
    Jun 2020
    Spokane
    Robyn, I am such a newb, sorry. So how would I go about checking the pop pressure?
    Why are you changing the pump?
    What are you changing the pump on?
    Are you sure you really need to change the pump?
    Scabby if your total DIY there was an article on TDP on how to build your own injector test set up using a grease gun and gauge to test pop pressure.
  1. Coolant Crossover Replacement
    By AugustDiesel in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-09-2017, 03:25
  2. Best Dmax replacement water pump
    By CoyleJR in forum Duramax 6600
    Last Post: 07-28-2014, 09:00
  3. LB7 Drivers Side Head Gasket Replacement & Turbo Removal
    By Bill Brayman in forum Duramax 6600
    Last Post: 05-13-2011, 20:49
  4. Guessing age of injectors? DIY replacement?
    By MarkMorissette in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-23-2008, 21:19
  5. NEW TDCO procedures?
    By Aryeh Levy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-25-2005, 06:51
