Thread: Filter breakage
    Jun 2020
    Seattle
    Default Filter breakage
    Has anyone heard of the fuel filter container actually breaking? My mechanic said that he suspect that it is broken. My idea is that the three hoses that connect to the filter housing are leaking. Either way I have a river of diesel fuel running down to the starter and below. Anybody ever replace a broken filter housing?
    They break, usually around the heater element.
    However, if you have fuel running down the passenger/right side, it may not be the fuel manager. The valley usually drains on the driver/left side, but can make a mess on either side if it's enough volume of fuel or the drain is plugged. More likely an injector return line or termination cap if the starter is getting wet with fuel.
    Feb 2006
    If it's a '93 or earlier, it could be the IP throttle shaft seal. Not usually a heavy leak like you described though.
    i had a soft plug in my rectangle filter housing start to leak on my 90's it was on the firewall above the starter,threaded the hole and installed a plug,been holding since.
  1. Newbie Question: Oil and Fuel Filter Changes?
    By 72Blazerod in forum Duramax 6600
    Last Post: 02-10-2012, 13:01
  2. 2009 LMM fuel filter change
    By Mark Rinker in forum Duramax 6600
    Last Post: 10-06-2010, 06:42
  3. Would this work as oil bypass filter?
    By atom_c in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-21-2006, 21:46
  4. 6.5TD STALLING - Air in Fuel Filter Housing
    By Mudtrekker in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-05-2003, 04:23
  5. Fuel Filter Problem
    By SPICER in forum Duramax 6600
    Last Post: 04-27-2003, 21:13
