I have a 1994 C3500 TD that has the OBD1 connector under the dashboard. My very trusty OBD2 scanner won't fit the OBD1 so I bought a converter cable that on one end has the OBD1 and the other has the OBD2. There is no response to the scanner because it looks like only 2 terminals on my truck's connector are even hooked up. Is there supposed to be any PO_ _ _
type codes offered in 1994? I do get the paperclip treatment to show a
DTC 36 but no other method to possibly display the PO_ _ _ style codes. What scanner can display PO codes from an OBD1 output connector, if any?
