Will someone please help me identify the name of the coolant hose in the attached image.
The hose comes off the Thermostat Housing and connects to the bulkhead. I know it is a coolant hose because I have a leak in it and coolant is coming out. There is a leak where the hose connects to the Thermostat Housing.
I doubt I am able to replace the threaded connector that connects it to the Thermostat Housing, so I assume I have to replace the entire hose.
Can the connector be replaced or do I need to replace the entire hose?
What is the name of the hose so I can purchase the correct part?
Thank you.
