TheDieselPage.com Forums
The Diesel Page Forums
2019 - TDP's 23rd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > TDP Classified ad forum
TDP Classified ad forum Non-Commercial Member diesel related classified ads
Reply
Thread Tools Display Modes
  #1
Old 06-05-2018, 05:24 PM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
Default Ats turbo setup for gm 6.2
I have a complete ATS turbo system for the 82-87 square body pickups
Also fits GMC JIMMY AND BLAZERS from 82-91 as well as Burbs from 82-91
ALSO FITS THE CREW CABS from 82-91
Will fit CUCV too
Good condition.
The turbo, exhaust manifold, air inlet casting that sits on the intake manifold.
Air tubes, hoses, clamps
Downpipe too (not in piccy)
You will need to fashion your own oil drain setup back to the sump. the turbo has a JIC fitting at the outlet.
Turbo spins free and has minimal slack.
This unit used the oem air filter and housing.
Great example of a fine unit from a bygone era.
Banks still offers their unit for $2995
This little jewel should fetch $1000
I will deal.
__________________
(1) 2007 Chevy Avalanche
  #2
Old 06-07-2018, 05:40 AM
Robyn's Avatar
A link to a current thread regarding the ATS turbo..
http://www.thedieselpageforums.com/t...ewpost&t=45713
__________________
  #3
Old 06-08-2018, 06:20 PM
rcpd34 rcpd34 is offline
Newbie
How difficult is this to install and get up an running?
__________________
Brian <br />301-370-8883<br />Nextel 164*71*315<br />2004 Chevy Silverado 2500HD 4X4 **FOR SALE**<br />2002 Chevy Suburban 2500 4X4<br />2001 Chevy Silverado 2500HD 4X4<br />2000 Chevy 3500 Dump 4X4
  #4
Old 06-10-2018, 06:18 AM
Robyn's Avatar
Hi
Pretty easy really
Remove the RH exhaust manifold and swap in the ATS manifold.
Bolt on the turbo charger
Remove the original cross over pipe
Install the crossover from the kit
With this system you need to install a 3 inch or larger muffler and a single pipe
The turbo downpipe connects to the new large exhaust.
Add a pipe T to the oil pressure switch port at the rear of the engine.
Use one side of the T to connect a stainless braided oil line to one port (Feeds the turbo at the top) and the original OP switch to the other side.
Connect the turbo drain line to either a weld bung in the pan or an adapter at the front RH side of the block by the fuel pump if equipped.
**** There should be a pipe plug down by the fuel lift pump on the block... use this as a turbo drain line port****
Mount the aluminum air plenum to the top of the intake.
Install the two air pipes to the air penum and turbo.
Turn the injector pump fuel screw about 1/4 turn CW
Fuel screw is accessed by removing the top of the IP.
Downloading the instructions from the Banks kit (still available online) will get you spot on.
The turbo and such are soooo similar and the tech instructions are really good
Rules of the game are the same
Link to the instructions
http://assets.bankspower.com/manuals...6.2-v4_web.pdf
The air filter system is different and a few other items...but the IP setup and such is really all you need.
THE FACTORY air filter housing and filter goes right back on top of the ATS air plenum.
Pretty much a weekend project if you get a plan together and have everything ready to go.
The oil lines are parts house stuff (Oil feed line must be stainless braid type)
Hope this helps
__________________
  #5
Old 06-10-2018, 08:25 AM
tpitt tpitt is offline
Enthusiast
Default ATS Turbo
Actually the oil return goes in the valve cover. You have to drill a hole and place a grommet in it. Somewhere I have the instructions. If I get a chance I will find them. This Turbo in my opinion is a better set up than the Banks!
__________________
2004 G.M.C. LLY CC D/A sb 4wd Summit White, ATS Duals, BD X-monitor, BD Exhaust Brake, Snugtop shell, 45 gal. Transferflow fuel tank, AFE stage II
2004 TDI Jetta GLS S/W
2005 TDI Passat GLS S/W
  #6
Old 06-10-2018, 08:34 AM
Robyn's Avatar
The truck this unit came off of had the oil return running to a nicely done bung on the RH side of the Pan
This is a lot of extra work...unless the pan is off for another reason.
Those instructions would be sweet.
If you can find them please post them here
__________________
  #7
Old 06-10-2018, 05:33 PM
Enthusiast
Soon as I get a chance. I'm a little busy right now so if you don't hear from me in a couple of weeks, please pm me. Thanks, Terry
__________________
  #8
Old 06-12-2018, 12:43 AM
john8662's Avatar
john8662 john8662 is offline
modeRATOR
This setup is not an ATS Turbo setup.
This is the BAE setup, very similar to the Banks setup except that it plumbs above or the factory air cleaner and uses a T4 turbo vs a T3 turbo.
The BAE turbo is a bit interesting too, never run one but I own the identical setup so I probably should try it.
J
  #9
Old 06-12-2018, 08:07 AM
Robyn's Avatar
Thanks for the heads up.
I was told that it was ATS
__________________
  #10
Old 06-13-2018, 03:49 PM
Robyn's Avatar
Took a good look at this turbo set up.
Has a Rotomaster HI-FLOW turbo with A/R 85
The crossover is nearly identical to the Banks system and comes up the Left side of the engine by the pan and then crosses by the front of the pan and then enters the exhaust manifold at the front right, and the down pipe exits the rear of the turbo and sneaks down past the frame above the starter just like the Banks units.
The turbo mounts with the shaft parallel to the engine center line but sits higher on the engine than the Banks unit.
I sent BAE an email and asked ????? but no response yet
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
