What color smoke does it make when going down the road that is fogging things?
The white/blue smoke is usually a result of timing, but can be other issues.
Can you get a mirror in there to see where the timing reference mark is on the timing cover? If so, compare this to the the mark on the injection pump.
Usually during a pump swap, a little timing advance is used by rotating the pump, usually a little more than a line width towards the driver's side.
I wonder if the pump was originally turned up a little before it was rebuilt.
As mentioned, replace the fuel filters, but should be just the one on an 85.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
