Results 1 to 2 of 2
Thread: Parts needed for jumpy belts 1982 GMC Jimny
    Jun 2020
    Buford
    Default Parts needed for jumpy belts 1982 GMC Jimny
    Do I need to replace both the harmonic balancer and install a dampened crank pulley or just the pulley? Can anyone give me part numbers?
    Randy
    Welcome aboard!
    Just the crank pulley, but it's always a good time to give the balancer a second (or third) look. The part numbers are very specific to application, so you'll have to look it up with a supplier according to VIN, or hit/miss comparison. Also check all the accessories for true running. Good luck!
    Or, if you're going to keep it a while, look into a serpentine belt upgrade. A bit costly up front, but almost all the headaches of V-belts disappear.
  1. Bought a 1982 GMC Jimmy 6.2T today
    By LaRell in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-09-2006, 20:40
