Results 1 to 11 of 11
Thread: pitman arm on the 6.5
    Dec 2002
    Teton Valley, Idaho
    Hopefully I'm posting to the right forum...
    The pitman arm from the steering box to the drag link on my steering system is loose on the drag link end, the end with the ball joint. Shouldn't be a big deal sez I, I've got a pitman arm puller for one end and a pickle fork for the other. Picked up the part at the local Napa store and dropped the splash shield to change it out... What's this? A cross member on the frame to hold that big ole diesel engine that leaves barely room to fit a box wrench on the steering stud nut, to say nothing of any way of using the puller to remove the arm from the box. Calling anyone with the Helms manuals: What does it say about this? A simple part replacement now looks like a serious job; maybe pulling the steering box mounting bolts? Any input will help.
    Regards,
    Rapid
    tom.mcinerney Guest
    I replaced pitman & idler arms last year. Had same initial reaction you wrote. Remember Helm instructed to remove idler arm pivot/bracket to get access with puller, it worked. And i think had to remove steer box bolts as you guessed, though maybe not all. I'll try remember check book tomorrow, think that's it.
    LucasEnglish Guest
    It only takes 15min to pull the hole stearing box. I pulled mine. A local shop told me after I was done you can remove some bolts and twist the box so you can get your puller in there.
    rjschoolcraft Guest
    I pulled the whole box out. It wasn't that hard. Check your idler arm too. I replaced both at the same time. Both were very loose.
    damork Guest
    I did the job a year ago and pulled the gear out as well. It is easier than it appears - bought the puller from NAPA as well. Get yourself some new orings where the steering hoses connect to the gear so you go back together without leaks.
    I know some talk about replacing the drag link with the gear in the truck but I don't see how you can do it without damaging something else and taking more time anyway.
    Aug 2003
    IL
    I have the helm manuals and you can forget what they say if yours is like mine. It doesn't take very long to pull the whole steering box off anyway. I could not find a puller that would hold up to the force of the arm coming off and it wasn't so that you could put it in a press. I had to take a cut off wheel on my die grinder and actually cut the pitman arm off. It was not much fun and I had to grind slightly in to the steering box shaft But I could not see any other way of getting it off since mine was so tight.
    LanduytG Guest
    Like others i pulled the whole thing. it is much easier to do that than fight it in place.
    Greg
    Dec 2002
    Teton Valley, Idaho
    Thanks! I'll try to tackle it this weekend and what was said about the idler arm on the other end of the drag link makes sense, I'll look at that closely as well. Winter's coming soon here and I just spent too much money on a new set of winter shoes for the truck; I'd hate to grind them down too fast cuz the front end won't stay straight. This may seem like a silly question but is there enough slack in the P/S hoses on the steering box to leave them in place or do they have to come off as well? Might be a good idea to keep a quart or so of fluid handy...
    Regards,
    Rapid
    Mar 2001
    Milton, MA
    Just loosen/remove the bolts holding the box to the frame, and take the pitman arm off with the hoses still connected. You only have to move it a small amount to get a puller on there. While you're at it, do the idler arm and tie-rods, and get her aligned, front end work is too dirty and crappy to have to go back under there after each part wears.
    -Chris
    '97 K2500HD 6.5TD 5-speed ex-cab SB
    XM Satellite radio/Alpine CDA-9835
    BETA FSD Cooler
    Dual Optima Red-Tops
    Dr.Lee\'s battery terminal mods
    Mobil 1 F/R diffs
    Powertrax Lock-Right in the rear
    TSM 14-bolt FF rear-disc conversion
    Front PowerSlot rotors/Hawk Carbon-Metallic pads
    Braided Stainless flex lines
    3.5" JK exhaust, boost mod, and guages (Sounds like a KW )
    '96 Impala SS - 9.5"/2800 stall Edge Converter, shift kit, Bryan Herter OBDI reprogram, Hooker cat-back (T-56 6-speed waiting to be installed)
    Randee of the Redwoods Guest
    I just had a local shop down the road do it for me. I had originally bought the pitman arm at Advance Autoparts for about $32 with plans on doing it myself. Well, it didn't pan out. The local garage replaced it for me for a reasonable $144 and change.
    Sep 2002
    Albuquerque, NM
    Not just a diesel problem. I had to replace it on my previous Suburban 1/2 ton and had the same problems.
    99 Suburban 3/4 Ton 4x4
