TheDieselPage.com Forums
The Diesel Page Forums
2019 - TDP's 23rd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 1992-00 6.5L Turbo Diesel - Welcome to the Internet's first discussion forum for the 6.5L diesel engine. Tips on performance, upgrades, cooling, fuel economy, troubleshooting and more.
Reply
Thread Tools Display Modes
  #21
Old 11-08-2019, 08:32 PM
DmaxMaverick's Avatar
Administrator
Quote:
Originally Posted by Bigrig594 View Post
....I'm working with a paperclip and Google after all lol.
There was a time, not long ago, we had only the paper clip. Then, along came The Diesel Page....
__________________
  #22
Old 11-09-2019, 07:00 AM
ronniejoe ronniejoe is online now
Enthusiast
The numbers matched up for the one the parts house looked up. So, I'm assuming it was the right tcm, I may have just looked up the wrong code chart or something. I'm working with a paperclip and Google after all lol.
The controller chassis part number can be the same for several models and years. However, the programming is different. Did you swap the EPROM from the old controller to the new?
Again, if you are getting engine related codes with your paper clip scanner, you have the wrong program or EPROM.
__________________
Ron
1995 K2500 Suburban 8600 GVWR 6.5TD towing 32' 1999 Wilderness 31G GCVW 16,300+ lb.
KD 18:1 pistons with KD splayed mains.
  #23
Old 11-10-2019, 08:24 AM
Bigrig594 Bigrig594 is offline
Enthusiast
Yes, I swapped the eprom from the old controller. I'm no longer getting engine codes, just trans codes.
They're all for the internals of the trans from what I could tell. I should have the new one in after this afternoon. So I'll know for sure if it was a build issue.
  #24
Old 11-10-2019, 10:46 AM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
The 4L80E is not a one tranny fits all.
There are subtle differences that cause issues.
A sensor that was not replaced could cause issues, as can the pressure regulator.
How old is the TPS on the Injection pump.
A flakey TPS can drive ya nuts and mess up throttle pressure and shift points...
If the TPS is not new REPLACE IT WITH AN AC DELCO
__________________
(1) 2007 Chevy Avalanche
  #25
Old 11-10-2019, 01:08 PM
Enthusiast
I replaced it with the in and output shaft speed sensors
  #26
Old 11-10-2019, 01:18 PM
Robyn's Avatar
What about the TPS on the IP ????
__________________
  #27
Old 11-10-2019, 01:26 PM
Enthusiast
The one I replaced was on the intake... didn't know there was one on my ip
  #28
Old 11-10-2019, 05:23 PM
Enthusiast
Sorry it was the ip not the intake.
  #29
Old 11-11-2019, 06:35 AM
Robyn's Avatar
The TPS fastens to the passenger side of the Injector pump and is coupled to the throttle shaft.
There is a small wire plug that plugs into the TPS.
A faulty TPS will/can cause many issues
__________________
  #30
Old 11-11-2019, 06:57 PM
Enthusiast
Ok, got the new trans in. Still popping through 1st and 2nd gear. Parking brake light comes on now, cruise control no longer works, but I do have all gears now.
Pulled codes 85 trans gear error and 87 transmission gear ratio error.
New parts include input shaft and output shaft speed sensors, tcm, tps, and brake switch.
  #31
Old 11-13-2019, 04:44 PM
Enthusiast
What is the tps supposed to be set at?
  #32
Old 12-01-2019, 08:17 PM
Enthusiast
Ok, I have officially replaced every sensor, still having the same issue
  #33
Old 12-01-2019, 10:48 PM
56pan 56pan is offline
Enthusiast
My 93 had a similar problem. Turned out to be the ign. switch. Burnt corroded contacts. Not that hard to remove and disassemble and look at. Or you could backprobe the TCM connector C277 at pins C16, wire no. 439, pink/black for battery voltage through the ign. sw. The 2 grounds at that connector are C1, wire no. 450, tan/white and C2, wire no. 551, black/white. At the trans. connector, you should have battery voltage through ign. switch at pin C and pin K. Do_not_remove the connectors and check the voltages/grounds with them disconnected as the circuit will not be loaded and you'll get incorrect readings. I'll try to attach scans of the two connectors from the wiring diagram from my alldatadiy info. Good luck.
  #34
Old 12-02-2019, 06:50 PM
JohnC's Avatar
JohnC JohnC is offline
Proud Deplorable
Quote:
Refer to post #3. Have you verified the trans and TCM have good power?
__________________
"Need" - Wanting to get someone else's money.
"Greed" (formerly meant what "need" means today) - wanting to keep your own.
"Compassion" - a politician's willingness to arrange the transfer.
-Joseph Sobran
Current oil burners: MB 350SDL, Kubota 7510
New ride: MB GLS450
Gone but not forgotten: '87 F350 7.3, '93 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Researching 4L80E to NV4500 Transmission Swap trbankii 1982-2000 C/K Truck & SUV Chassis & Drivetrain 19 08-10-2016 10:02 AM
FS: Misc 6.2 & 6.5 Parts -Montana AsphaltCowboy TDP Classified ad forum 1 08-04-2015 12:08 AM
Some 6.5 diesel "Gum shoe" Robyn 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 4 08-29-2011 07:17 AM
1995 C3500 2wd 6.5 Clutch Issue clem_acc 1982-2000 C/K Truck & SUV Chassis & Drivetrain 6 02-06-2008 07:46 PM
Best Diesel Shop in Salt Lake City to diagonose Timing issue on 6.5? Mitch-SLC 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 0 03-04-2005 07:03 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
