Results 1 to 11 of 11
Thread: Stumbling on Deceleration
    Default Stumbling on Deceleration
    Hi
    Just finished changing the motor in my 97 3500 4x4 standard.Everything went good.The doner motor came from a 97 2500, i replaced the intake with the original non egr one.Both had the same inj pump.
    I now have a hesitation/stumble when i decelerate.This happens when driving and when revving in neutral.So far there are no codes being thrown.
    Anyone come across this before?
    Thanks Thomas
    May 2014
    us, ga
    Did you ever figure this problem out? Thanks
    Hi Aftermath
    This was a truck i got used,it had electrical gremlins.It wasn't used everyday just as required.After i changed the engine i went trough a couple of PMD's which were remote mounted,and were not Stanadyne units. Then i replace the ignition switch.Then one day i went to start it and it wouldn't fire,this was after driving it into my shop and shutting it off.By then i had accumulated everything to convert it to mechanical.I tried a few things and gave up and started cutting wires,now there is a computer living in the dash screaming away because it dosn't get any input and the truck does/did everything normal.Till the crank broke.
    So i bought a Dmax tow truck,should have bought the Dodge Cummins truck,but i am a die hard GM guy.
    Thomas
    May 2014
    us, ga
    Hi Aftermath
    Thomas
    So I have a buddy that is experiencing a similar problem, issues on decelleration. Really nothing else I can find on this specific issue.
    Try changing the PMD
    I went through a couple of the aftermarket ones in that truck,they were remote mounted.
    You mention it was a '97 4x4 standard - which I assumes means manual transmission? I'm curious about what else the computer controls (or tries to)? I'm thinking about MFI on my '94 and would swap in a manual at the same time, but then got to wondering what else I'd have to tinker with. ABS? Instrument cluster? Other things?
    There was nothing else effected by the swap.
    My ABS was already disabled,all guages worked fine.
    I lost the high idle through the computer,just used a manual high idle.
    Just out of curiosity, what resistor do you have on the PMD? I recall when I had a high number (don't remember if it was 9 or "13") on a pump that called for a 4, I had issues with surging just off of idle. Seems like when it transitioned from "closed throttle" to the pedal reading it gave too much fuel. I theorized it's because fuel rate at idle is based on RPM whereas off idle it's calculated, and the high number forced it to calculate a higher rate.
    Nov 2002
    Martinsville, IN
    I tested the SOL-D FSD for TDP a long time ago. When descending a grade with the cruise set and the BD TorqLoc engaged, that thing would cause the engine and truck to surge and buck violently until you turned the cruise off. I dug a little deeper and realized that the engine would hunt or surge when descending a grade with cruise off as well, it just wasn't very noticeable. The SOL-D apparently had troubles with metering fuel rate under no load situations. In fact, my negative review probably sunk that whole project.
    This never happened with a Stanadyne FSD. I would look at the FSD as a potential culprit.
    Thank you for the input. I can't say that losing ABS would necessarily be a bad thing as far as I'm concerned.
    I prefer the ABS delete option myself...
    One of the joys of living here,no inspections to worry about.
