TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > GM Medium-Duty
GM Medium-Duty Learn more about GM's new medium-duty trucks and diesel engines.
Reply
Thread Tools Display Modes
  #1
Old 07-11-2008, 04:38 PM
Mark Rinker's Avatar
Mark Rinker Mark Rinker is offline
Enthusiast
Default Turbo issue - 2004 LB7 with 97K miles
On my way home with unloaded trailer from Seattle to Minneapolis, started to hear a faint squeal similar to a belt slipping, when under acceleration.
Checked belt/tensioner - no problems. Finally on a steep downgrade I engaged the exhaust brake (not normally used when empty) and the squeal was constant and definately boost related...
With doghouse removed, the squall is unbearably loud. Turbo is functioning normally under moderate throttle but noise occurs under acceleration and activation of exhaust brake. Power and mileage normal, no black smoke even under heavy acceleration with squeal present.
Not sure if its a bad turbo to intake seal or a bad wastegate, but the truck is going in Monday to get it addressed - a smidge under warranty expiration.
__________________
  #2
Old 07-14-2008, 07:55 AM
Duramaster's Avatar
Duramaster Duramaster is offline
GMC World Class Technician
Hey Mark! Just saw your post on the turbocharger. Sounds to me like it is a burned out exhaust manifold gasket. Use this tool http://www.sears.com/shc/s/p_10153_12605_00945164000P Take the probe end off so that you just have the hose attachment on. Trace the hose around the exhaust manifolds and turbo area. Anywhere there is an exhaust sealing area. Good luck with that.
__________________
  #3
Old 07-14-2008, 07:37 PM
Enthusiast
It was a seal - as you guessed. They stripped or broke a bolt when disassembling, a new tube/gasket are on order. Warrany will cover the fix.
__________________
  #4
Old 07-15-2008, 06:08 AM
Duramaster's Avatar
Cool! Hopefully it's not broke down for too long.
__________________
  #5
Old 07-15-2008, 07:13 AM
Enthusiast
Me too - we are trying to get out of town with a boat today or tomorrow...back to Seattle.
__________________
  #6
Old 07-15-2008, 08:16 PM
Enthusiast
They fixed the leak mentioned in previous post, only to discover another at the exhaust manifold. Both are now corrected.
Also addressed a small oil leak on drivers side of block. Said it was a block plug (?) that needed resealing - not the oil fill or dipstick tube that I had suspected.
My last smidge of warranty will run out on the next trip to Seattle - so I guess this is the end of the road for cheap fixes. (Although GM extended the injector warranty to 200K and put it in writing shortly after replacing all 8...)
$105.
__________________
  #7
Old 07-15-2008, 08:34 PM
AKMark AKMark is offline
Building another 6.2L powered vehicle
Lucky you, all my problems happen after warranty is long expired.
I no longer buy vehicles with warranties, much cheaper to buy, and I learn how to fix myself. When they break away from home, you are up a creek, but that's the way it goes. I don't own a business like you do, so I can get away with it a little easier.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
