TheDieselPage.com Forums
The Diesel Page Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.2L Diesel
6.2L Diesel 1982-93 6.2L Diesel - Welcome to the Internet's first discussion forum for the 6.2L engine.
Reply
Thread Tools Display Modes
  #1
Old 10-12-2018, 11:06 AM
4077th 4077th is offline
Newbie
Default Resealed my injection pump, stalling issue.
I'll try to keep this short. Posted on 2 other boards, with no replies.
Does anyone know if the throttle shaft can be installed on the min-max gov linkage incorrectly? I know the top cover of the Db2 pump itself can be installed on the wrong side of the gov linkage (causing a run away) but this is not my problem.
Truck runs great at WOT, mid throttle, good timing, good power, no air in the system verified by a clear IP return line. Truck runs perfect.......
It just WONT idle after reasealing the IP. I had to bottom out the low idle screw to get it to 500 rpm ish. Idles kind of rough, but is smooth if I hold it open a little further.
So i'm thinking 1 of 2 issues. I either goofed installing the throttle shaft on the governor shaft (shaft has 2 steps) or tank sock is plugged. I know the Db2 pulls fuel well at higher RPM but not much at idle. I'm pushing through a 10 micron and 2 micron with a 12v lift pump.
  #2
Old 10-13-2018, 10:22 AM
Newbie
Backed the governor nut out 1 full turn. Truck is back to normal, idled a little too high but a little backing out on the external low idle screw got it in the sweet spot. She runs like she did 3 years ago, and with all the new seals is leak free.
It was a great learning curve completely re sealing this pump, I would do it again in a heart beat. They are really simpler than the shops let on. Big thanks to DieselPro at DieselPlace and all the Stanadyne manuals.
  #3
Old 11-18-2018, 12:42 PM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Glad you got it fixed.
I have replaced the throttle shaft seals and the top cover seal, but never the entire package
__________________
(1) 2007 Chevy Avalanche
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
