Thread: 01 lb7 2500 hd coolant leak
    Apr 2020
    WALLINGFORD
    Default 01 lb7 2500 hd coolant leak
    hey guys! Need some help. My duramax is running great but noticed a small leak at the drain plug on the oil cooler. Might be the drain plug seal but not sure. May be coming from the weep hole. No other coolant leak that I can find. Definitely slowly losing coolant. Anyone have this problem? Thanks!
    I think the coolant is coming from elsewhere...
    Are your hoses hard when /after you have the engine running?
    I have a lb7 that has excessive pressure in the hoses,i think...
    But the point is it had numerous small leaks in the system because of the excessive pressure.I tightened all the offending clamps and the leaks disappeared,pretty much.
    My truck is parked 98% of the time,it is a tow truck in a small town.So the issue hasn't made it's way to the top of the list.I add some coolant every 6 months or so depending on use.
    On mine,my guess is an injector tube is leaking.
    An uneducated guess based on what i have read here,i have never been inside a Dmax.
  1. Coolant leak, rear of engine. Where is it coming from?
    By vilago in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-07-2012, 15:56
  2. Coolant Leak Help!
    By mstockton in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-01-2009, 11:59
  3. Coolant Leak?
    By ak46champ in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2008, 22:30
  4. Low coolant-Leaking head gasket update
    By Maverick in forum Duramax 6600
    Last Post: 09-06-2002, 20:57
