I had an 81 C20 that I converted to a 6.2L diesel turbo with a 700R4, 4.10 gears, and 31" tires. I felt it was the perfect combination for power and economy. Like mentioned above, the 700R4 has a steep overdrive, so it makes the 4.10 gears happy on the highway but still leaves you with the proper gearing for towing. I think sticking with your current combo is a good idea.
