Thread: New optimizer Heads ID help
    Jul 2016
    Calgary, Alberta
    Default New optimizer Heads ID help
    I’m looking at a set of (95% sure) new optimizer heads.
    Can you folks decipher the casting numbers for me. It has what appears to be the Navistar casting marks
    S/N # 10137667
    S6090 (this one could be upside down. It works both ways 0609S)
    The one pic with the "Double Diamond" casting mark....Navistar casting
    Whats the story on the heads.?????
    They appear to have been installed on an engine.....silicone goop remnants on the Valve cover lip..
    The bolt hole pad shows having had contact....
    Feb 2012
    Pauline, SC
    Only sure way is the precups will have a ball to locate them in the head and be magnetic if china or other. Real gep will have non magnetic cups and a bump for the locator...
    1993 Chevy K3500
    like us on Facebook
    Jul 2016
    Calgary, Alberta
    They came off a new optimizer motor, but the engine was for a hummer, so they took off the heads to put the hummer units on. Never been run apparently. I’m gonna have to check the pre cup as trailrider said.
  1. Remanufactured cylinder heads
    By OIL BURN in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-25-2013, 18:16
  2. 162 6.2 heads on a 6.5
    By Snowbound98 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-17-2013, 06:34
  3. Heads and Gaskets, what are the final rules? Story included.
    By john8662 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-27-2004, 20:38
  4. Question about heads and rebuilding....
    By Lothar in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-12-2004, 08:38
  5. Questions: Heads, Injectors, IP (long)
    By jcomp in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-14-2004, 15:50
