The Diesel Page Forums
2019 - TDP's 23rd Anniversary
Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > GM Medium-Duty
GM Medium-Duty Learn more about GM's new medium-duty trucks and diesel engines.
  #11
Old 10-20-2012, 02:39 PM
cowboywildbill's Avatar
cowboywildbill cowboywildbill is offline
Moderator
Thanks, I also tried using my Tech II but didn't have any luck.
0000000
  #12
Old 10-20-2012, 08:12 PM
Inspector's Avatar
Inspector Inspector is offline
Moderator
Question
Do you have High beams.
Denny
2006 Jayco Seneca 35GS, C5500 chassis, DA 6 SPd, 360hp,
LBZ, Bilsteins Edge with Attitude level 3. True 4" turbo back, high flow muffler. Super springs and Firestone airbags
Member # 128.
  #13
Old 10-22-2012, 04:31 PM
Moderator
Cool
I have high beams and all four bulbs work for that. if you flip the lever to low beams they all go out. If you turn the headlight switch off and E brake off I have DRL's. ???????
If I turn the switch to parking/running lights I get the DRL's which look like low beams. ???? but if you rotate it to headlights it has no low beams. And only high beams if you flip the turn signal high low beam to high beam setting. ????
0000000
  #14
Old 10-22-2012, 04:48 PM
Inspector's Avatar
Moderator
Question
I think that the DLRs get there power through the dash sw when it is in the off position. That being said you have high beams and not lows. It is my opinion that the high/low stem sw is ok. The DLRs have to go through the low position on the stem sw. It is my opinion that the dash sw is the problem. just sayin.
Denny
Member # 128.
  #15
Old 10-23-2012, 02:26 PM
Moderator
Thanks Denny. At least it's the easier switch to replace.
0000000
  #16
Old 10-23-2012, 02:35 PM
Inspector's Avatar
Moderator
Wink
Before you replace the sw make sure that was plugged in properly.
Denny
Member # 128.
  #17
Old 10-25-2012, 04:08 PM
Moderator
Did that thanks
0000000
  #18
Old 06-22-2013, 03:24 PM
Ricky bobby Ricky bobby is offline
Newbie
Default What was the fix?
Can someone tell me the fix on this one?
  #19
Old 11-03-2015, 03:27 PM
RF1954 RF1954 is offline
Newbie
Anybody figure out the remedy on low beam problem ?
  #20
Old 12-24-2015, 01:46 PM
SID6FIVE SID6FIVE is offline
Default low beam issue
the few times I have seen this, the 5-pin relay for the headlights or low beams got switched somehow with a 4-pin relay...usually swapped with another relay next to it...weird things happen, much as you describe...
SID 6.5 THE DIESEL GUY AT ROSEDALE CHEVROLET IN MINNEAPOLIS...
