TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.2L Diesel
6.2L Diesel 1982-93 6.2L Diesel - Member access forum for any questions or information exchange related to the 6.2L engine.
Reply
Thread Tools Display Modes
  #11
Old 05-24-2017, 11:44 AM
AugustDiesel AugustDiesel is offline
Enthusiast
Quote:
Originally Posted by convert2diesel View Post
I have to assume you are using the old (88) computer. The tps had only two functions when mated to the 700R4. Controlled the EGR (if installed) and commanded the lock up. Your shift patterns are controlled with a throttle valve in the tranny connected via a cable to the throttle quadrant.
The lockup is activated any time you go into 2nd gear or higher and the throttle position is less than 1/3 to 1/2 throttle position (33% to 50%). If you want to go to full manual control of the lockup, you're going to have to disconnect the tps altogether and or the computer and install a switch in the transmission ground position of your data port (I think it is the terminal on the far right of the OBD connector under the dash). The switch will override any command from the computer.
As I said in my previous post you are going to have to be vigilant as you don't want to have the tranny going through the gears with the convertor locked up. Your brake switch will still unlock the convertor as before. Ran the Buick with this setup for close to 100K without issue, after I got used to unlocking it when appropriate. You're also going to need a piece of electrical tape to stick over the check engine light
I would try a new TPS first. You may find your issues disappear. Try the cheap fix first.
Hope this helps.
Bill
Those TPS switches sure aren't cheap. I'm seeing prices of $100-$150+. Does that sound right?
By cheap fix, are you referring to the Bypass Switch? Unplug tps, connect wire to far right terminal of obd data port then to toggle switch on dash then to ground?
__________________
1988 K10 Suburban. 6.5L NA Goodwrench Engine: 506 block cast on August 12, 1996. Heavy Duty built 700R4. Full-floating 14 bolt rear axle. 3/4ton 10 bolt front. Brand new 305/75R16 Procomp AT Sport tires on brand new 16x8 steel wheels.
  #12
Old 05-24-2017, 01:47 PM
DmaxMaverick's Avatar
Administrator
It's not exactly that simple. You need a diagram and verify which end of the circuit needs ground, and which needs Batt+. There are also pressure switches inside the tranny (valve body), that complete the ground to the solenoid (bypass them). Yours should have 3, maybe 4. I have a diagram scan for my 85 I can send you (email), if you want to give that a try. It just happens to have the TCC circuit highlighted.
__________________
  #13
Old 05-24-2017, 04:34 PM
Enthusiast
Quote:
If only things were that simple ... I'll pm you, thanks!
However I may just try replacing the tps first. But then again, I do have to tear into the valve body anyways to install the transgo 700-2&3 kit ...
__________________
  #14
Old 05-24-2017, 09:31 PM
convert2diesel convert2diesel is online now
Enthusiast
I beg to differ. It is that simple. Have used this method on three vehicles.
Mechanically, the convertor gets its pressure from the second gear circuit but lock-up depends on either the 3rd gear pressure solenoid or the 4-3 pulse solenoid giving it a path to ground through the computer. The lock-up solenoid has a two second delay built in to momentarily unlock the convertor during shifts. The TPS also has to be below 33% to 59% for the computer to command a lock-up.
Grounding out the upper left (TCC) data terminal (sorry had to recheck my old records to be sure), through a switch, by passes the whole works actually giving you lock up in the top 3 gears including second (very disconcerting when you forget to turn the switch off). You can also bridge the upper left to the upper right (ground) to achieve the same thing.
You're right. The TPS is expensive. Used to be less than 50 bucks. If you can get access to it, loosen off the two mounting screws and turn it counterclockwise all the way then take it out for a spin and see if that corrects your problem.
This is a "hall effect" sensor and before you condemn it, you should check the output voltage through the entire throttle range. There should be 3 wires coming out of it:
5 volts
ground (typically the black wire)
output.
With the plug connected, you should have access for a thin probe to the back of the terminals. With the key on, not running, use a voltage tester between the ground and one of the other two terminals. Find the one with 5 volts. That is the power. The other one is the one you want as it is the output voltage. With the key still on, open the throttle slowly. You want to see a smooth transition from just under 1 volt to close to 5 volts from the output terminal. If you find it jumps suddenly from one voltage reading to the next (i.e. 1.5 volts to 3 volts) then the sensor is toast. If the voltage rise is linear, then your sensor is good.
The TPS signals an unlock condition below 1 volt (coasting throttle off) and above 2.5 to 3 volts if memory serves.
Another thing you probably won't want to hear is the possibility that your IP is going south, needing more throttle angle to achieve the same power. That would mean the throttle is to far ahead and the TPS is commanding a convertor un-lock.
Hope this helps
Bill
__________________
94 Cadillac Fleetwood (sold)
08 Aerolight 23TT
06 Vortec Max Silverado CC SB (finally got all the bugs worked out)
  #15
Old 06-06-2017, 10:38 AM
john8662's Avatar
john8662 john8662 is offline
modeRATOR
1988 - 1991 6.2's with the 700R4/4L60 did have a Throttle Position Sensor, not a Switch. The TCC lock on these truck is controlled by the PCM.
Adjustment is critical, ensure you adjust the sensor and roll the throttle through full throttle and observe voltage. You should see a smooth increase in voltage.
If not smooth, the sensor is bad, I have seen many of them defective and would cause the PCM to disable lockup.
Search the forum for adjusting the TPS on a 6.5 MFI truck (92-93) to get the procedure. Requires a digital volt meter.
The TPS from the 92-93 6.5 is the same, just has a different connector on the end of the sensor. I've swapped these in a pinch.
__________________
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
  #16
Old 10-24-2017, 11:13 AM
Enthusiast
Just wanted to provide an update on this:
Installed the toggle switch as prescribed by convert2diesel. Ran like that for a while, able to lock the TC with the toggle switch. However, TC continued to sporadically engage/disengage unpredictably when the toggle switch was off, so I pulled the TPS out completely. Took it for a ride and seemed to operate fine. I now can engage/disengage the TC manually when I want it to be. Not a permanent fix likely but seems like it will suffice for now.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
