Results 1 to 8 of 8
Thread: re-awakened from the dead
    Jan 2007
    Victoria, BC, Canada
    Default re-awakened from the dead
    I have a 1998 K3500 that has been sitting for about 11 years that I'm going to try to re-awaken tomorrow. I moved to Canada 12 years ago and was unable to import it at that time because it was modified (6" procomp lift kit) but now that it is older it is subject only to provincial rules and the liftkit is fine.
    I intend to do an oil change and put new batteries in before I try to fire it up, but what else would you all recommend? I need to drive it across the border under it's own power before I can get it into my shop.
    After getting it there, doing the main seal might be a good idea. And a thorough check over everything of course. But what else specifically would you recommend changing out after that amount of time that I might not otherwise think of?
    Thanks! Looking forward to re-joining you all here!
    1998 Chevy silverado 3500 4x4, 6.5TD, 215000 miles, 4L80-E, 4.10 ratio, 6" lift, gauges and intercooler... and a newly rebuilt engine on new block and heads!
    Feb 2012
    Pauline, SC
    Fuel, oil, antifreeze, air filter, fuel filter...
    1993 Chevy K3500
    like us on Facebook
    Jan 2007
    Thanks! Definitely got those on the list.
    (Pauline, SC. Nice! I went school at Furman over in Greenville. Great part of the country.)
    Check the brakes very carefully! Leaks and frozen calipers...
    You don't want to be crashing through the boarder crossing!
    Feb 2003
    Grand Rapids MN 55744
    If possible drain the fuel tank, stuff can grow in there and create all kinds of problems. They also make a tank cleaner product that might be a good idea.
    Was the truck exposed to salt in its life? If so REALLY check all your brake and fuel lines. Bring with a spare fuel lift pump.
    Good luck!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Jan 2007
    Thumbs up
    Fantastic, thanks for all the thoughts! She made it home safe and sound. Runs well enough I think I'm even going to try to slip her through the inspection before putting her up on a hoist and going top to bottom. Pretty great after being set in a field for so many years! I think it was the wasp epicenter of Clallam county, though. 33 wasp nests came out of her. Still cold enough in the mornings that I got them all without getting stung, though.
    Boy, that car wash was a gratifying experience! (pictures attached)
    Quote Originally Posted by derekja View Post
    Holy cow! That was one filthy truck!! She sure cleaned up nicely, though.
    Great before and after pic's
    I bought a sea can in southeast Alaska that has been sitting in the woods for about that long,and looks like your before pictures.
    Glad to see it will cleanup,i was going to use it for myself instead of a rental.I wouldn't want it sitting in my yard if i was paying rent on it.
