Thread: What's the difference between 6.2L engine #14022660 vs #12552929
    Apr 2020
    Arizona
    Default What's the difference between 6.2L engine #14022660 vs #12552929
    Good Morning. I'm new to this site and forum however I've known this site for 20 yrs. I bought my 1st diesel back in 2001 1985 Chevy K20 (6.2L) "J" code which I only enjoyed driving it for 9mns and broke down. After 19yrs of sitting I decide to bring it back to life (yay). I need some help here I recently bought a completed drop-in from a guy who didn't want the engine for $250, I’m not 100% sure if it was a "J" code, vin # was remove long ago off truck.
    What's the difference between my old 6.2L (14022660) and new/used engine (12552929)?
    I would like to still use my current transmission and transfer case if this new engine works. Any help you guys can give me is greatly appreciated. Thanks Bits
    Apr 2020
    Arizona
    How could I confirm if engine is a "J" code, if VIN number is not available?
    Welcome aboard!
    You'll find the info you need in the 6.2L/6.5L Diesel - Upgrades & Service Forum. The 6.2/6.5 Cylinder Block Date Code thread describes the differences in the blocks, and when they were available.
    There is no difference between C and J code engine blocks. The difference is the intake and emissions systems, and in some cases, the heads (not significant). If the intake has EGR, it's a C code, and the original fuel injection pump would have been calibrated for slightly less power (a simple adjustment). The intakes are interchangeable within the vehicle models. A van or HMMWV intake will not fit pickup/SUV heads (the bolts angles are different). Chassis models can vary, depending on application.
  1. Engine won't shut off
    Last Post: 11-09-2005, 09:46
  2. NEW TDCO procedures?
    By Aryeh Levy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-25-2005, 06:51
  3. New 18:1 Engine Complete
    By Hansh in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-25-2005, 03:06
  4. '83 6.2L engine parts
    By Hye in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-16-2004, 18:46
  5. How to turn down Injection Pump off engine, & TURBO ?'s
    By john8662 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-13-2003, 22:10
