Results 1 to 6 of 6
Thread: Broken Transmission Filler Tube
    Apr 2020
    San Luis, CO
    Default Broken Transmission Filler Tube
    First Post -Newly Purchased 1992 3500 - just turned over to 100,000 miles.
    Was smoking a little , put new Air filter in and added some Diesel Extreme Injector additive (after I filled it up) Made a HUGE improvement, no smoke.
    Two Questions- Advice on if I can replace filler tube, broke off where it is connected to the block, about a foot up from entry into transmission. Sure hard to get your hands up there. Lastly, Engine sure is a dog, (compared to myold gas 454). Up at 8000 feet altitude.. any performance adjustments?
    Welcome to TDP
    The filler tube slips up out of the tranny.....remove the bolt that held the old one to the block and remove the old tube.
    Slide in a good tube from similar rig (used) or replace with a new tube.
    Replace the rubber seal or O ring DEPENDING ON WHAT WAS IN THERE...
    Is this a 6.5 Turbo or a 6.2 engine????
    The 6.5 turbo should be fair in the power dept if the turbo is operating properly
    The 6.2 N/A engine is going to be a bit of a slug at that altitude
    Let us know...
    Robyn - Master of the Understatement.
    John
    I was being polite
    The 6.2 NA at 5000 ft is a real Turd...I can't imagine adding another 3K to the "Turdism" GOAP oh yess
    Even a good running 6.5 turbo is no barn burner at 8K
    Apr 2020
    San Luis, CO
    Default Broken Transmission Tube
    AAh, So if I can get something around the broken tube, and manage to disconnect it where its still mounted to the block, with some force, it should just pull out. Gotcha I will order a new one.
    The 6.2 is N/A
    Just loaded a 11 ft Lance Camper on it. An old Rig and old Camper, no rush to go anywhere too fast.
    Thanks for your help.
    The tranny tube is just a slip fit into the tranny case.
    Some used a single O ring on the tube in a groove, and others had a special multi ring rubber gizmo with a flange on the top that pushed into the tranny and the tube slipped into that.
  1. Allison code list, tq. specs, and other info
    By Bobo in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-26-2015, 18:30
  2. NV4500 Tranny Trouble
    By 6.5 Detroit Diesel in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 07-21-2012, 22:32
  3. Transmission leak at dip tube
    By JackRH in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 07-19-2011, 10:46
  4. oil filler tube gasket
    By Mr. Bone in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-19-2006, 11:37
  5. The transmission filler tube
    By Low_Bridge in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-21-2004, 03:39
