Timing Gear Set Splash Shield
Did early 6.5 or 6.2 engines have a splash shield mounted in between the camshaft timing gear and the fuel pump gear attached to the camshaft gear? Seems i recall one at a point. You would install the shield after the camshaft gear was installed and prior to both fuel injection pump gears installed.
