Yup, sounds like standard PMD / FSD failure. It's a little black box that was mounted on the side of the injection pump from the factory. If it's still in that location, you need to purchase a PMD, PMD extension harness, and a PMD remote mount to locate it in a cooler location.
On my 1995 model, I have a D-tech FSD mounted on an FSD cooler right in front of the driver's side battery where it receives air flow from a hole in the radiator support.
Search for PMD failure, and you'll find tons of info.
