Thread: Duramax starter motor replacement
    Jan 2017
    Western montana
    Default Duramax starter motor replacement
    Two years ago I had flexplate and starter motor replaced on my 01 Duramax due to significant grinding on start up. Everything was fine (except for the bill) until about 4 months ago. Turned the key and starter made a grinding noise and truck did not start. Discovered the starter was loose. Tightened the bolts up in a mud puddle as best as I could and had no problems, before leaving on vacation I crawled under the truck to check motor again and discovered it was loose and also one of the ears on the starting mount was broken. I got new starter from Napa in a hurry since we were leaving soon. I replaced the starter motor myself which in my opinion is a significant pain in the ass to replace. When I went to start engine I heard the dreaded grinding noise that I spent a $1000 dollars to have fixed. The truck does start but grinds directly after motor is started.
    My question is what is causing this and what should be my next plan of action?
    At this point point I plan on removal of the Napa starter and replacing it with an Delco starter.
    Did I get something wrong during installation. How can I keep the bolts from loosening again. Could the flywheel need replacement again already?
    Thanks for any help.
    2001 Lb7 Dmax 1 ton dually
    185000 miles With Hillsboro flatbed
    30 ft bumper pull camp trailer
    Dec 2002
    Teton Valley, Idaho
    is that on the starter or on the mounting flange?
    The starters on these trucks tend to be very robust and give very few issues for many hundreds of thousands of miles. So good that I wouldn't be afraid to put a good used OE on. For years I have resisted buying any reman starter or alternator whenever possible. Instead, I have a semi-local auto electric ship rebuild mine.
    Once you have the starter in and working properly I would pull the bolts one at a time and put a drop of red loctite on the threads. Not a lot, just a bit.
    Jan 2017
    Western montana
    Thanks for your responses . An ear broke on the mounting flange. Napa starter is brand new but I think it does not disengage fast enough.
  1. Starter How to
    By Robyn in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 09-12-2011, 14:54
  2. Remote starter for Duramax
    By royalglen in forum 2500HD/3500 Accessories
    Last Post: 12-16-2009, 08:38
  3. Starter problems - '04 Duramax
    By RobJJ in forum Duramax 6600
    Last Post: 10-29-2007, 06:01
  4. After 10 years, I finally fixed my starter....
    By arveetek in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-02-2006, 09:51
  5. Inline 6-Cylinder Duramax
    By chevyguy in forum Duramax 6600
    Last Post: 03-01-2003, 07:45
