TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5L Turbo Diesel - Welcome to the Internet's first discussion forum for the 6.5L diesel engine. Tips on performance, cooling, fuel economy, troubleshooting and more.
Reply
Thread Tools Display Modes
  #51
Old 05-23-2018, 06:05 PM
JeepSJ JeepSJ is offline
Jeep Freak
Someone recommended the heads from SS Diesel because they are supposedly USA castings. However SS couldn't tell me if they had hardened seats or inserts. I'm just leery of the steel pre-cups in the Chinese heads. SS also said his had steel cups, which are superior to the factory stainless steel cups and people should quit reading what people write on the internet about the steel cups.
__________________
  #52
Old 05-24-2018, 06:09 AM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
The Heads I bought were ordered right from Clearwater.
I stayed away from all the second and third party sellers.
I tried sorting through all the hype on who's heads have what casting, made in what third world country, shipped to the US for machining, and using which original GM parts, that were remanufactured in what dumpy shop in Chicago ????
The stories are so convoluted and embellished with BS that's laid on with a trowel it's impossible to ever find the real truth.
I spent over an hour on the phone with a fella at AMG after I scored the AMG block with the mainline that was .0025 too small, and we covered the entire story on the after market parts that are out there.
The folks at AMG certainly have the ability to separate the fly chit from the pepper and they are even at a loss as to who has what, made by who and with what parts...
As I mentioned before, the Clearwater heads served me well...
I have no doubt that they are not as good as the AMG parts, buttttttttttt, when $$$$$$ are a big factor the CW heads are not a bad choice.
Trying to make a well educated choice on this subject will drive ya crazy...
Good luck
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
  #53
Old 05-24-2018, 10:36 AM
Jeep Freak
Quote:
Amen. I have spent too many hours researching this. Latest seller finally agreed this morning to refund all of my money and doesn't want them back. So now I have 3 set of heads lying around.
Interesting that I had a chat with Odessa regarding their rebuilt GM heads and asked them what they did about the cracks. He came right back and said they pin them all. Maybe when this is all said and done and I have some extra time, I'll call up the folks at Lock-N-Stitch and have a go at repairing a set of these and see how they turn out.
__________________
  #54
Old 05-25-2018, 07:01 AM
Robyn's Avatar
FWIW
I personally would not waste one thin dime on a set of well used GM 6.5 heads
Besides cracking they have coolant flow issues internally (likely causes the cracks) and once you have a crack, getting it to stay pressure tight is going to be a crap shoot.
Even a pinhole leak into the coolant passage will/can cause overheating, coolant loss.
The lower end cracks can be arrested and stabilized as they do not allow and real issues, unless the breach the oil passage and allow pressure loss, or travel up into the lower cylinder area and into the water jacket..
The best use for an old set of 6.5 heads is using them as door stops...or maybe a boat anchor...
Back in the dark ages I fooled with the 5.7 Olds diesels...
The cars could be purchased CHEAP once the Diesel started giving issues.
I had a 79 Calais that was a sweet heart... but would over heat and blow the water out....sound familiar
I got real good at getting the heads off these rigs fast.
I finally found the issue on that rig... One cylinder had a tiny pinhole that was leaking, and the shops only mag'd the heads (no pressure test)
I built caps for the coolant passages and aired the heads up.
found the pin hole....
Decided to drill it out and thread the hole for a pipe plug.
Plugged it and then peened the hole well to prevent the plug coming out
The spot was on the fire deck so was easy to deal with.
That thing ran for many years that way..
Glad you got your $$$$ back...
__________________
  #55
Old 05-25-2018, 09:05 AM
More Power's Avatar
Administrator
Based solely on my own personal experience with crack-repaired OE cyl heads, I don't have a problem with them. I have extensive experience with "crack between the valves" repaired cyl heads (>300K miles). A cracked block on the other hand scares me too much to consider investing any money in one - considering how much quality machining costs these days.
  #56
Old 05-25-2018, 09:13 AM
ronniejoe ronniejoe is offline
Enthusiast
Those repair kits from K-Line to sleeve the drilled passage between the valves that you wrote an article about years ago are not available any more -- I checked last fall.
The concern I have with the cracks between the valves is progression through the seat. There is no way that it won't eventually leak compression.
I've had some good luck with repaired heads that were furnace welded to repair cracks. The problem is, the source that I used has quit doing the repair. They've gotten into marketing their own aftermarket race heads and don't want to do repair work anymore. I can't find anyone else who will do it.
__________________
Ron
1995 K2500 Suburban 8600 GVWR 6.5TD towing 32' 1999 Wilderness 31G GCVW 16,300+ lb.
KD 18:1 pistons with KD splayed mains. Read about it here: Part I, Part II, Part III.
  #57
Old 05-25-2018, 10:41 AM
Jeep Freak
I have one of the K-Line kits with enough liners left to do 3 more heads.
Seeing as how every head I have checked so far has been cracked across a seat, the repair would be...
- Pin the crack from one end to the other using Lock-n-stitch pins. That would potentially start in the intake port, up through the valve seat, across the chamber, through the exhaust valve seat and into the exhaust port. Not all were that bad, but of the 6 heads that were crack-checked by my machine shop, every head had at least one crack that went through a valve seat.
- Install hardened seats on the intake and exhaust
- Install the Kline liners
I'm hoping that a head that has hardened inserts installed in the exhaust and has not been induction hardened will not have a cracking issue.
So far I have found 2 suppliers (SS Diesel being one of them) that claim their castings are US and that have hardened inserts. SS is more expensive, but the other supplier doesn't appear to have rotators installed on the exhaust valves. That is an easy fix though.
__________________
  #58
Old 05-25-2018, 01:19 PM
More Power's Avatar
Administrator
The sleeves are standard size valve guide liners. So, any decent head shop will already have the reamers and liners. Don't need the kit. The engine shop here in Montana that has done these for me in the past didn't use a kit.
Cracks of any kind - found in either a head or block - always come with a fear of progression. I have enough miles of trouble-free experience with crack repaired heads to know that there are more important things to worry about.
The repaired cracks I've seen in heads that had been torn down for other reason were filled with compacted carbon in the seat. Compared to piston ring leakage? Anything with a crack is not perfect. Myself included. Perfection remains a goal.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
