Thread: Deep aluminum transmission pans
    Aug 2000
    Riverside, CA USA
    Default Deep aluminum transmission pans
    The marketing for the aftermarket aluminum pans stress the additional 3 to 4 quarts of oil they provide. Since a 4L80E is close to 16 qts to start with, an additional 4 quarts is about a 25% increase in volume. Nice, but not huge. They also say aluminum is a better disipator of heat than steel. The stock thin steel transmision pans seem to be hot in use and can dissipate some heat. None of the manufactures of larger aluminum pans provide any hard data on temperature reduction, just they presume you will take it on faith their product is better than stock. Anyone have some real word data on these?
    83 C10 Suburban, Silverado, 6.2, 700R4, 3.73, 31-10.50R15
    82 C30 Crew Cab dually, 6.2, Banks, Th400, 4.10, Gear Vendors, 235-85R16
    83 C20 Suburban, Sierra Classic, 6.2, 700R4, 4.10, custom paint, 285-50R20
    95 Yukon, 6.5, 4L80E, 3.42, 265-50R20
    73 GMC Astro 95, 8V71, 10 speed Roadranger, 110" WB, 6 each 11R24.5
    Aug 2000
    Riverside, CA USA
    No thoughts on this topic? I'm guessing these pans are as more for the "bling" than for heat reduction. They do look nice.
    Oct 2005
    edmonton
    Default aluminum pans
    just a thought but for the price of a Al pan would you not be able to put on a second cooler? I would think that would be more cooling for the buck.
    86C 6.2l gmc
    "This to shall pass"
    "Life is to short for a Tim Horton Line up"
