Results 1 to 2 of 2
Thread: general question concerning diesel fuel
    overland,mo. usa
    Default general question concerning diesel fuel
    I recently drained some fuel into a clean glass jar to check for water in the fuel. I noticed after a few days the fuel had turned very cloudy after standing. The jar was tightly sealed during this time. Just curious if this is normal.
    member#5832 1995 C3500 Ext cab 6.5 TD Auto. 2WD 4:10 Rear 4L80E L65 cold air intake, cooling sys upgrade,PMD heatsink,80 hp chip, performance cam, marine inj's, high volume oil pump, all ports in heads polished, turbo ports all polished, timing gear set, stainless steel oil cooler lines, boost, trans temp, pyro guages, large trans pan, exh man's heat wrapped, 4 in exh.no cat. no muffler 56000 miles
    Quote Originally Posted by kenisret
    Was it cold?
