TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ, LMM & LML engine specific topics.
Reply
Thread Tools Display Modes
  #221
Old 03-12-2018, 07:25 AM
richp richp is online now
Enthusiast
Default Continuing the Saga
Hi,
Just returned to Illinois from Quartzsite towing the fiver. I have122k miles on an '09 LMM. No problems going down in January, but several 0087 episodes on return last week. Absolutely stock truck with auxiliary filtration and regular Power Service throughout its life. Regular filter changes. Regular Chevy dealer service at the same competent location. No lift pump (duly noted, John).
Obviously, working through this thread gives possible short and long term answers. But my solution for getting home the last 1,000 miles -- starting in western Oklahoma -- was to keep post turbo EGT's in the 1,000 degree range, and never more than 1,100. I used that as a proxy for the temps the injectors and incoming fuel were experiencing. I did this by doing a lot of manual gear selection on hills. I recall only one post in this entire thread that mentions that approach. Hmmm.
I will figure out my future with this truck somehow. But when other brands of diesels are notable for much longer injector life, it makes me wonder what GM has stuck us lifelong, committed customers with.
FWIW.
__________________
Rich Phillips
Member #27
09 K-2500 Standard Cab
Universal Fuel Filtration
In The Past: '82 6.2 Jimmy Blazer, '93 6.5 GMC K-2500, '01 DMAX K-2500
  #222
Old 03-17-2018, 08:06 AM
Enthusiast
Hi,
My dealer had it for two days, and as I expected, found nothing wrong -- injectors test solid, no codes left, and absent the load from towing heavy, on hills, while hot, no way to get their equipment to register my issue. They report all fuel lines solid, the fuel cooler clean, and no leaks anywhere.
These are two guys who know the truck since new, have serviced it thoroughly and regularly, and otherwise have my confidence. So for now I'm going to drive on and see what the future holds.
They did offer a thought that freeing up the exhaust might help keep overall temps down and thus keep the returned fuel cooler. Coming from a dealership, I found that interesting. Any thoughts on that from anyone?
__________________
Rich Phillips
Member #27
  #223
Old 03-17-2018, 10:25 PM
CoyleJR CoyleJR is online now
Enthusiast
Default P0087
Hi Rich,
I agree with the dealer that opening up the exhaust would help cool the motor by lowering the EGT a little. I do not think it will get you a substantial drop in fuel temperature. Additionally, the noise caused by most large exhaust systems will make for a very long trip from Illinois to Arizona next year.
My post about the P0087 code was the one posted just before your post (take a look). If I keep plenty of fuel in my fuel tank it seems to cool the returning hot fuel and stop the P0087 problem. When your truck threw the p0087 code did you have over half a tank of fuel? I think a second fuel cooler would cool the returning hot fuel a lot better than a larger exhaust system. Just my thoughts on the P0087 code.
Good luck
John
__________________
*2006 Chevy, 3500, 4X4, DRW, (LBZ) D/A, CC, LT, 245K Miles, 19.5" Wheels, Mag Hytec Transmission Pan and Differential Cover, SS Grill Guard, Racor 2 micron aux fuel filter, 100 Gallon Aux Fuel Tank, using Edge Evolution, Predator Diablosport, Kennedy ECM tune, Fitch Fuel Catalyst.
*2008 Forest River, 38' 5th Wheel,
*2007 Pontiac Solstice
*1958 Willys CJ3B
  #224
Old 03-18-2018, 04:55 AM
Enthusiast
Hi John,
Thanks for the response.
I usually fill up at the end of the day's run with the fiver, so I can get a fast start in the morning. And I have been getting a few hours of clean performance -- until the tank is lower and the day is warmer. So refueling more often might help, although it would slow the day's progress.
I have pondered adding another cooler. Insofar as I recall, nobody in this thread has mentioned actually doing it, or a supplier with suitable hardware. So that is an option with dangling questions...
And yeah, the exhaust noise issue has occurred to me, and would be a turnoff. In addition to my own objection, I might never get Maureen to ride with me again. A very last resort, I think.
I appreciate being able to add your thoughts to the mix.
__________________
Rich Phillips
Member #27
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
