Results 1 to 6 of 6
Thread: 07 Duramax in C5500
    Mar 2001
    williamsburg, ohio ,usa
    Default 07 Duramax in C5500
    Just started serviceing 4 new 2007 C5500 buses w/ DA's, 5 more on the way. Local bus company is overwhelmed w/ work on their 50+ over the road buses so we will service their smaller ones for a while. The engine is stout enough to spin the duals in packed gravel, haven't found anything else to do that in the back lot! Sure is tight in engine area, trans area is nice and open. Did not notice a fuel cooler. had to relocate the exhaust pipes to meet state specs, all had the new cooling tip on the exhaust end to help deal w/ regen heat. Hopefully we will service long enough to see any problem w/ the new emmissions requirements. bob............
    Bob O.
    2004 K2500 DA LLY CC LT LB Wow! Edge w/A + BS + CAT pre fuel filter, 06 air box,
    2002 C6500 EC. 7.2 Cat NoMar rollback/ 92 C7500, 7.2 Cat, 25ton No-Mar / 2005 C5500 D/A rollback / 1969 Corvette 350-350 4spd AC T-top stock orginal
    XP850LE WOW nice ATV, 09-550XP hers, 03-Predator, 04 Honda400EX, 05-Banshee, 08-KTM525, 08 KFX700, 38' enclosed GN hitch
    NutNbutGMC Guest
    Thanks Bob. Always nice to know folks are getting a first-hand observation from the ones in the know.
    Default c5500
    please tell me what you might know about the kodiac chevrolet 6.6 diesel egr coolant on a 2006
    Mar 2007
    Pacific Northwest
    Question
    What are you getting at JACK? Is there a specific problem?
    Myrtlehead, TX
    carco:
    Forgive a simple question, but do you know why the c5500 advertise less hp than a regular pick up truck? I'm considering a replacement for my 3500 and might upsize.
    Mike
    2002 GMC, Pretty Dark Blue, 4x4 / 3500, ZF6, 115 gal spare tank and Rockets... (My Other One): Flying Fuel. I got three engines and a 52,000 gallon tank, how many you got?
    May 2002
    White Hall, AR
    I think they govern the trucks @2500rpms so they dont rev the horses out like a regular pickup (32-3300ish)
    2002 Pewter 2500HD D/A EC SB 4wd Warn 12K SOLD! 103k miles
    2007 White 2500HD CC SB LBZ 4wd Warn 12K Stock
