Thread: Additive question
    Default Additive question
    I've been using Stanadyne Performance formula in my truck since I bought it a couple of months ago. I noticed that the bottle says "store above freezing". I'd like to keep a bottle of the stuff in the truck, but I wonder if this could be a problem during the winter months? Anybody know what happens to this stuff when it gets cold?
    I am going to venture a guess that in it's concentrated state it may seperate out. One thing for sure once you put it in the tank the stuff can certainly get exposed to below freezing temps.
    Not sure. Call stanadyne up on the phone and ask them directly.
    Its their product so they should have an answer for you.
    I personally have never used any of the patent skunk piss additives in my diesels.
    The only product I have ever used has been tranny oil and it seems that this is turning out to be not such a good idea.
    Hope this helps
    Robyn
    Apr 2007
    Quote Originally Posted by bobbennett33 View Post
    Check out Diesel Kleen in the white bottle it is for cold temps,also if you keep a bottle inside the truck you might want to put that bottle in another container.
    If you don`t,the inside of cab will smell like the additive,not real pleasant.
    I use a old water jug,and I won`t leave it in the cab any longer than I have to.
    Standadyne is pretty much the same as Diesel Kleen in the silver jug,not for below freezing.
    2007.5 GMC Sierra 3500 BLACK SRW C.C. 4X4 LMM/Allison,long bed,Loaded,Westach EGT/Boost pass side, Edge Insight CTS EGT driverside, DIY stock airbox mod, aFe proguard 7 OEM airfilter. Back-up sensors + Back-up camera tied into the navagation screen, Redi Lift leveling kit, Cognito UCA's, Pitman Idler arm support, AMP Power steps, Firestone Air bags with controller in cab.
