Results 1 to 2 of 2
Thread: 6.5 fuel pump issue on WVO
    Feb 2008
    Kentucky and Clemson SC
    Default 6.5 fuel pump issue on WVO
    I am having veggie fuel pump issues and would like some advice from all you running a 6.5. I cracked my walbro fuel pump (auxillary pump with greasecar kit) that came with my kit before I installed it, so I used the $60 holley diesel micro pump from advanced (I know it was wishful thinking that it would last very long), and it worked well till recently when it started to make the truck stutter a bit going up a hill. ( on veggie oil) The mountains of Colorado finally ate it on my trip last week. So I ordered a Raptor fuel pump from pureflowtechnologies.com, expensive as hell but super heavy duty and has a life time warranty. This this has fully adjustable pressure and flows 100gpm. I installed it and the truck still does not like to go over 2500 rpms or up hills with the pressure turned to the max (at which the truck runs the best), (adjustment screw has 4 turns to it, set at 12-15 psi and i am 3 turns past that). Now the Walbro pump flows 45 gph at 10psi. The guy I bought it from says that greasecar is nuts for using 1/4 PEX line for the fuel pick (1/4 in PEX line inside a coolant hose to keep it heated) up because it is way to small and will collapse under heat. Any thoughts?
    Sold: 98 2500 ext cab long bed 4x4 auto 166k, Lubrication Specialties oil cooler, FSD cooler, Walking J "feed the Beast" mod, Heath HD lift pump, SSdiesel turbo back exhaust, Heath mechanical boost controller, Softtopper camper top, boost, egt, fuel pressure gauges
    1970 El Camino SS, built 355, aluminum heads, Lunati cam, intake, 800 cfm edlebrock, Tremec 5 spd, QA1 Coil over all around, Wilwood discs up front, 3.73 Posi 12 bolt, Viper Red
    2012 Audi A3 TDI- Love it! 45 mpg!
    May 2000
    Portland Oregon US
    How many mile on your VO filter? If you are pushing that much fuel pressure and GPM then you have something plugged most likly your VO filter.
    2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars.Blocker Plate. Burkhard PCV Re-Route
    Greasecar Kit with Automated CoPilot, 200 gal WVO tank. Inline Particle Counter for ISO rated WVO Cleanliness.Time to go fishing, Now I pass everything including the fuel station. .
