Thread: Super 60 Turbo??
    Feb 2020
    Stony Brook, NY
    Default Super 60 Turbo??
    Anyone have any experience/thoughts on running a Super 60 turbo on an Optimizer 6500. Truck is an '85 CUCV with a 4l80 and NP 205. Daily driver...little heavy hauling. Looking to swap out the 6.2.
    Whats a super 60 turbo?
    You will need a banks turbo kit to run a turbo in your straight body truck,or be really good at fabricating.
    The turbo from a 5.9 cummins is supposed to be a good match.
    Feb 2012
    Pauline, SC
    the so called supper 60 is a renamed Holset HX40..
    You would find a hybird holset 35/40 would serve you very well and with not much input you can build it yourself with real holset parts..
    1993 Chevy K3500
    like us on Facebook
    Dec 2009
    In the North
    Quote Originally Posted by Navydoc View Post
    iirc,. Cucv' have some deep rear end ratio's, so you are probably going to operate in an rpm range where the HX 40 would do you fine for less money with no lag,. Jmho.
    1999 chev suburban C2500
    300,000 mi
  1. Banks TE06H-24 Turbo, Banks 6.2L upgrade turbo
    By john8662 in forum TDP Classified ad forum
    Last Post: 07-28-2014, 13:13
  2. Que up interest, ATS 6.2 incomplete Turbo KIt.
    Last Post: 10-16-2010, 11:47
  3. Garrett Turbo Super Charger Appicability
    By Stage1 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-18-2004, 13:15
  4. Preview of new air-box from UMP
    By BlueOx03 in forum Duramax 6600
    Last Post: 01-23-2004, 10:41
  5. How to turn down Injection Pump off engine, & TURBO ?'s
    By john8662 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-13-2003, 22:10
