Results 1 to 9 of 9
Thread: Out of ideas trying to start a 98
    Jan 2020
    Michigan
    Default Out of ideas trying to start a 98
    Still trying to start 98 6.5 problem is I can pull glow plugs from heads and get a mist but when I try to start I get no smoke out the back end and it doesn’t even act like it wants to start also have all new Bosch plugs. The batteries are old 2014 but it still turns over, however when I check voltage I have 12.1, I took them to advance and and got 513 and 423 cca my question is is there a min voltage the pmd needs to spray fuel I think with cranking under load (with the plugs in) and heating glow plugs could it be pulling voltage down to much for the pmd
    Feb 2012
    Pauline, SC
    The motor needs to turn over fast, with old batteries it may not be spinning fast enough...
    1993 Chevy K3500
    like us on Facebook
    Jan 2020
    Michigan
    But shouldn’t I still get smoke out the back?
    With the electronic pump there's no fuel until you break minimum RPM. It might be 200 RPM, but I'm not sure any more. What's the battery voltage(s) at cranking speed?
    Dec 2000
    Hawaii/Arizona
    Bill D,
    You indicated that there was no smoke from the back. Check your air intake and exhaust system, a small mouse nest can cause big problems.
    Good luck
    John
    *2007 Pontiac Solstice.
    Festus, MO.
    I believe min crank speed is 400rpm.
    Big Green
    I had a 94 that did that to me at that grocery store. Sounded like it was cranking fast enough but wouldn't hit minimum RPM to get the fuel solenoid to open. Have someone crank it while you have you hand on the solenoid and see if its clicking open. If it doesn't it time for batteries. Make sure the solenoid works first.
    Dec 2009
    In the North
    A 6.5 starts best when its whizzing over,. Slow rpm equals poor injector pressures,.pull couple of glows and manually verify they are working well
    1999 chev suburban C2500
    300,000 mi
  1. Cold start problem.
    By DIESEL/VETTE in forum Duramax 6600
    Last Post: 03-25-2015, 13:08
  2. 6.5TD Will Not stay running, Hard to start, then shuts off after bucking/kicking?
    By 97Suburban in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-11-2015, 19:46
  3. Hard to start
    Last Post: 10-29-2013, 13:23
  4. Won't start. Ideas needed-Please take a look
    By restoguy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-23-2008, 18:57
  5. '01 Dmax getting harder to start
    By chessy56 in forum Duramax 6600
    Last Post: 01-23-2008, 18:33
