Thread: How far out is my speedo????
    May 2000
    Canada
    Quick question for you tire junkies out there - I went from 245/75-16 to 255/85-16 - how far out is my speedo going to be - dealer tells me likely around 10 kph (6 mph) Does this sound right??
    Where can a guy post pics instead of Picturetrail???
    01 Chevy 2500HD ShortBox/ExtCab Duramax/Allison 4x4 White/Graphite Drivin it and LOVIN IT!!! <br /> 2002 Yamaha SX-Viper snowmobile! <br /><a href=\"Http://www.picturetrail.com/duramax\" target=\"_blank\">Http://www.picturetrail.com/duramax</a>
    Mar 2002
    L.A.
    255R85 means 255mm wide and 85% times 255mm high.
    245R75 means 255mm wide and 75% times 245mm high.
    If you double 85% times 255mm times .04mm/in and add 16in (rim size) you get 33.07in which is the diameter of your new tire. Do the same for 245R75 and you get 30.47in for the diameter of your old tire. Divide 33.07 by 30.47 and you get 1.085 or an 8.5% error (slow). Figure that you're going 65MPH when your speedo says 60MPH.
    It's real, I made the same swap and checked it with a GPS.
    Mar 2002
    L.A.
    245R75 means 245mm wide by 245mm times 75% high.
    Apr 2002
    calgary ab.
    If you want to post pictures try:
    http://photos.yahoo.com
    they have a service that is free or you can expand for a small cost.
    [img]smile.gif[/img]
    2003 SLT Duramax CC/SB Carbon Metalic, Juice\'d, JK Light harness, HD sprayed box liner, J&J Millennium running boards, Fumoto valve, Tekonsha Prodigy brake controller, TFP Stainless door handle inserts, Michelin LT265/75R/16, combination Tool Box & Fuel tank(165L) with timed transfer flow, 2 Micron CAT Primery fuel filter, dndstarr@shaw.ca<p>PIC\"S <a href=\"http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax\" target=\"_blank\">http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax</a>
    May 2002
    Oxnard, CA
    I bookmarked this site to play with all the differing tire size questions
    http://www.c5-corvette.com/tirecalc.htm
    On the left side put int your old tire as tire A, your new tire as tire B. Use the center selection for comparison, and voila:
    Speedometer Error
    Actual Speed Indicated Speed with Tire B Speedometer Error
    5 mph (8.04 kph) 4.61 mph (7.41 kph) -0.39 mph (-0.63 kph)
    10 mph (16.09 kph) 9.21 mph (14.83 kph) -0.79 mph (-1.26 kph)
    15 mph (24.13 kph) 13.82 mph (22.24 kph) -1.18 mph (-1.90 kph)
    20 mph (32.18 kph) 18.43 mph (29.65 kph) -1.57 mph (-2.53 kph)
    25 mph (40.23 kph) 23.04 mph (37.06 kph) -1.96 mph (-3.16 kph)
    30 mph (48.27 kph) 27.64 mph (44.48 kph) -2.36 mph (-3.79 kph)
    35 mph (56.31 kph) 32.25 mph (51.89 kph) -2.75 mph (-4.43 kph)
    40 mph (64.36 kph) 36.86 mph (59.30 kph) -3.14 mph (-5.06 kph)
    45 mph (72.41 kph) 41.46 mph (66.72 kph) -3.54 mph (-5.69 kph)
    50 mph (80.45 kph) 46.07 mph (74.13 kph) -3.93 mph (-6.32 kph)
    55 mph (88.50 kph) 50.68 mph (81.54 kph) -4.32 mph (-6.95 kph)
    60 mph (96.54 kph) 55.29 mph (88.95 kph) -4.71 mph (-7.59 kph)
    65 mph (104.58 kph) 59.89 mph (96.37 kph) -5.11 mph (-8.22 kph)
    70 mph (112.63 kph) 64.50 mph (103.78 kph) -5.50 mph (-8.85 kph)
    75 mph (120.67 kph) 69.11 mph (111.19 kph) -5.89 mph (-9.48 kph)
    80 mph (128.72 kph) 73.71 mph (118.61 kph) -6.29 mph (-10.11 kph)
    85 mph (136.76 kph) 78.32 mph (126.02 kph) -6.68 mph (-10.75 kph)
    90 mph (144.81 kph) 82.93 mph (133.43 kph) -7.07 mph (-11.38 kph)
    95 mph (152.85 kph) 87.53 mph (140.84 kph) -7.47 mph (-12.01 kph)
    *EDITED to 95MPH for obvious reasons*
    [ 02-11-2003: Message edited by: DMAX Daddy ]</p>
    Randy<br />2003 2500HD C/C D/A Pewter -Retrax Cover -Michelin LTX M/S 265/75E-16\'s -Smittybuilt Step Rails -Banks Exhaust -CA Hot Juice -Predator - Kennedy Headlight Harness -SPA 211
