TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ, LMM & LML engine specific topics.
Reply
Thread Tools Display Modes
  #1
Old 06-11-2018, 05:22 AM
Bigshankhank Bigshankhank is offline
Enthusiast
Default 03 LB7 Limp Mode
Helping a friend diagnose his Duramax. Approx 180k miles, he bought the truck at 110 and the PO stated that he had replaced all the injectors recently. Highway driving, not towing, engine started running rough and CEL illuminated and speed dropped below 30.
Codes P-0201, 0204, 0206, 0207, 0700, and 2146 all came up.
I have read some of the threads on here about limp mode but they all seem to relate specifically to the 01 LB7. I also reached out to John Kennedy for some advice, but any thoughts here?
  #2
Old 06-11-2018, 06:33 AM
DmaxMaverick's Avatar
Administrator
With all the injector control circuit codes across both banks, I'd suspect a harness or connector issue first. Check all the under hood connectors. A loose connector or bent pin(s) will cause all kinds of havoc. The P0700 code is only the TCM commanding the MIL. You'll need a more capable scanner to read the actual tranny code, but I suspect it's likely a complaint due to the rough running. Chase any tranny issue after the engine is where it should be.
__________________
  #3
Old 06-11-2018, 06:45 AM
Administrator
Also check the battery health, terminals and connections. Poor voltage management can cause issues with the injector driver and tranny.
__________________
  #4
Old 06-11-2018, 06:57 AM
More Power's Avatar
Administrator
Go to: https://www.thedieselpage.com/#search
Enter P2146 in the search box.
Best info ever...
  #5
Old 06-11-2018, 09:25 AM
Enthusiast
Excellent info, thank you. My buddy is a charter boat captain and has both a lot more wiring experience than I do as well as a lot more free time, so he is going through the harness and connections and testing circuits and grounds, so it sounds like he should be able to find it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
