TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > 2001-2019 Chevrolet & GMC 2500HD/3500 Light Trucks > 2500HD/3500 HD Trucks & Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 01-13-2020, 12:21 PM
More Power's Avatar
Administrator
Arrow 2020 10-Speed Allison
New Allison® 10-speed transmission
Quote:
New Allison® 10-speed transmission matched with proven Duramax 6.6L Turbo-Diesel
Maximum power and towing capability in new Silverado HD lineup comes from the proven Duramax 6.6L V-8 Turbo-Diesel with 910 lb-ft of torque. Its towing capability is increased up to 52 percent with driveline improvements including the addition of the all-new Allison® 10-speed automatic transmission — a legendary Duramax/Allison® combination that contributes to the Silverado HD’s 35,500-pound max towing rating, when properly equipped.
A diesel after-run feature specifically for use following a demanding towing situation is an additional new technology for the Duramax engine. The after-run allows the engine to keep running for up to 15 minutes to allow it to cool down using the fan and circulating coolant. If the driver puts the truck in park when an after-run situation is needed, an alert will appear on the driver information cluster directing them to keep the engine running for cool down. Should the customer ignore the message and exit the vehicle, the truck will restart on its own via remote start mode for cool-down. At that point the customer can walk away and the truck will turn itself off when the engine reaches an acceptable temperature.
The all-new Allison® 10-speed automatic transmission combined with improved driveline components is better at transferring all of the Duramax’s torque to the pavement, allowing more torque to be put to the ground in lower gears, enhancing the overall driving dynamics and trailering with smoother gear changes and shorter steps between them. It also supports smart engine braking, which can help reduce brake wear. The Duramax/Allison® combination’s standard axle ratio is lowered to 3.42:1, which reduces engine speed, therefore enhancing refinement.
“The 6.6L V-8 Duramax diesel and Allison® transmission is a legendary combination in the HD truck market with proven durability and capability that our customers expect,” said West. “For 2020, we made the combination even better and upgraded nearly every driveline component. As a result, we deliver all 910 lb-ft of torque to the ground in first gear.”
For customers powering other equipment with their trucks on the job site, an all-new, factory-integrated engine-driven Power Take Off (PTO) is available and eliminates the need for an aftermarket unit. Exclusively offered with the Allison® 10-speed transmission on select diesel models, it’s the first fully integrated PTO system of its kind in the HD truck segment, with the PTO’s drive gear operated via chain to direct engine power. And because it is engine-driven rather than turbine-driven, owners can use the PTO while the vehicle is idling. A button inside the cab enables the PTO, and a mode selector allows adjustment of load and torque output.
  #2
Old 01-13-2020, 05:13 PM
rapidoxidationman rapidoxidationman is offline
Enthusiast
And people wonder why we are diesel enthusiasts.
It's the torque.
910 LB-FT in first gear? There's gonna be some good tire roasts happening until the driver gets used to it.
__________________
'85 Mercedes Benz 300D, for when I want to be stately.
'05 Mercedes E320 CDI, for when I want to be even statelier.
'05 Chevy K2500 ext cab long box DMax: Everything my '03 was and so much more!
There's no point being a pessimist - it wouldn't work anyway.
  #3
Old 01-14-2020, 10:30 AM
More Power's Avatar
Administrator
If I remember correctly, GM Powertrain limited the D/A torque in 1st gear for the 2001-04 LB7 because of the potential to unintentionally spin the tires while starting out heavily loaded. Now, there's close to 2x the torque with the newest engines...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
2003 LB7 motor and Allison 5 speed tranny for sale Rick Henderson TDP Classified ad forum 6 01-07-2011 11:06 PM
Will a 6 speed Allison fit a 6.5 v8 Sonofagun12G 1982-2000 C/K Truck & SUV Chassis & Drivetrain 4 10-03-2010 05:25 AM
Six speed '06 Allison plutonium233 Duramax Diesel Performance Shop 1 01-24-2008 11:10 AM
Allison 1000 5 speed gear ratios eric777 2500HD/3500 HD Trucks & Drivetrain 3 12-27-2007 04:41 AM
Allison or zf 6 speed? Ron Yates 2500HD/3500 HD Trucks & Drivetrain 17 06-10-2002 11:24 AM
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1996-2020 by TheDieselPage.com - All Rights Reserved
