Results 1 to 20 of 26
Thread: Cummins Powered Chevy
    Fort Bragg. All America USA
    Talking Cummins Powered Chevy
    She runs. [img]smile.gif[/img]
    Still tinkering with gages, but have it all figured out.
    Have yet to have the heart to cut up the front end to install the cummins intercooler. Have it, but won't use it. Using one mounted near where 92-01 chevy intercoolers mount, and with the 2" body lift, there is a ton of space to mount an intercooler.
    Wayne [img]smile.gif[/img]
    Road test went well.
    [ 08-03-2004, 03:48 PM: Message edited by: DogDiesel ]
    93 Chevy 4x4, 1 T 5sp Diesel Depot 18:1 ceramic & graphite coated pistons, balanced 6.5TDA, Ceramic lamenated head & exhaust manifolds, Marine 300 HP pump, hi-pop injectors, GM8 turbo with custom manual boost controller; intercooled (19 LBS BOOST), big exhaust, hi-output water pump & dual thermostats, programable glow plug controller, 60G glow plugs, Custom boost & pyrometer gages mounted in former flip-out ash tray, 50 gallon external fuel tank 900-1500 cruising range, goose, RV and receiver hitches; all-in-all--just a little modified for towing. <br />85 Mercedes 300SD <br />81 VW DIESEL Pickup - my sweet & immaculate high MPG daily driver <br />66 Bronco (itchin to put a Mercedes 5 cyl into)<br />59 Dexta with 3 banger Perkins Diesel<br />81 Ford 4X4 Compact Diesel tractor<br />I\'ve driven only diesels since 1979-I think I am a convert. <br />DP # 1146
    Talking
    She runs out great.
    Everything works except ONE THING. I simply cannot find the connecter for the oil pressure switch. I saw it and marked it when I pulled and installed the cummins, and it is still there somewhere, but I have felt, reached, dug, groped and cannot locate it. With the harness right near the left rear head, space is limited and tight. Wish I could remember the color.
    Fall-back plan will be to splice in at the wire into the dash and run a jumper to the switch or put the cummins sender in and use the dodge wire connecter (2 pin). Don't need the fuel pump.
    I'm running a temporary intercooler. The turbo technology cooler I used with the 6.5TDA. have the dodge intercooler, doubtful to install it. Guess I'll eBay it and find another that suits my taste. Have towed, and temp setup is OK.
    As for fan, I use a full-time Flexilite 418 with a modified 592 2" adapter. It was 3/4", and my fan center is 1", so I milled it out, dowelled it for centering and installed. You'd never know the fan was there for noise. Runs true. With the cummins, you'd not know a lot was there as far as noise goes. It is 3/4"+ from the radiator, and you can see it reach for the radiator as it pulls air. It is 18" and really flexible. Build my fan shroud next week.
    Summary of mods:
    Warpspeed 4" Dodge exhaust - modified front pipe.
    K&N filter kit - modifed mount shroud and pipe.
    Flexilite manual fan. See above.
    Power steering Dodge 2 hose to chevy three hose (TEE).
    Modified NIPPON-DENSO alternator to self-exciting one-wire and added "W" wire for tachometer, which works perfect, as the Dodge RPM pickup did not work.
    GM Bell housing and flywheel. 12" flat face LUK clutch and PP.
    Made mod mount for hydraulic actuator stud to bell housing (one hole missing on GM bell).
    Engine & tranny shifted 2" rearward.
    Shortened rear drive shaft 2"
    Cab lift 2 " to close hood.
    Notched one bolt mount for AC pump.
    The rest is small stuff.
    The Cummins makes more noise than the 300HP 6.5TDA, pulling power is about the same, but acceleration is a no-brainer, the 300HP 6.5 wins EZ. Empty or loaded. Holding speed on the hill, goes to Cummins. Getting lost speed back on the hill goes to the 300HP 6.5. We'll see about mileage. Have I opened a bucket of worms?
    Post Edit. I recinde these above comments. After I fixed a collasped fuel hose problem, the Cummins pulls wonderful, and holds speeds like the 6.5 could not, so getting speed back is no issue. RPM and sporty feel goes to the 300HP 6.5 which pulls good too. Cummins mileage is slightly better.
    Wayne
    [ 08-26-2004, 04:35 AM: Message edited by: DogDiesel ]
    markrinker Guest
    What is it that gives the Cummins the characteristic rattle? I have been in a few Dodge's that were so noisy you couldn't hear the radio over the idle.
    CareyWeber Guest
    DI vs IDI
    Lightbulb
    New found Power.
    Hooked to my RV...and power to beyond 2000 RPM then was flat. Surge and dip on pulling power. These symptoms could not be felt running empty. Empty accellerates to nearly 3K fine. Calculated it must be collasped fuel line or a pinch.
    Stopped at NAPA and bought 4 feet each of 5/16" and 3/8" fuel hose, the stiff kind. Replaced fuel lines from steel at electric pump forward. My God, she woke up!
    I have pull power to 2700+ and RPM to 3K. Pulling on cruise is weird, because when it accellerates, it feels like it is floored then smoothes out.
    In an above post I stated the 300HP 6.5 out accelarates the cummins. I recinde that comment. Preliminary finding.
    Gears 2 & 3 go to the 6.5 due to more RPM but in 4th and 5th where torque rules. Bye-Bye. I got to 85 MPH (all speedo does) in less distance than the 6.5 ever could. And no smoke.
    This conversion has been intense and a McGyver project from start, but with my towing needs, I'm on to something.
    Oil pressure sender.
    Dodge Cummins sender is a no-go. Apparently, this model used a charge light, because the two prongs on the sender were ground and neutral, with oil pressure they reversed. Have to stick with the GM sender and use the center prong. No luck in finding that oil-P/connecter wire. Know it is there, but it won't reveal itself.
    Towing day-after-tomorrow 400 miles and back to pick up a Ford 4000 4WD tractor. Mileage should show itself.
    Tow RV to MD this weekend.
    Project on-going.
    Wayne
    Ft. Wayne, In.
    Cool
    Wayne,
    Great project. Can't wait to hear how the towing goes! Keep us posted!
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Sep 2003
    Feeniks, Aridzona
    Dog - we need pics! Also, how about a write up about the project? I know where there is a 95 4 door dually with a worn out 454 - it is just begging for a diesel.
    Angry
    Need help.
    1993 Chevy Cummins conversion from 6.5TD.
    Problem: Cannot find the oil pressure switch connecter. Was there when I installed the 5.9L but now it is a mystery. Can run my hand blindly behind tall Cummins head. Found three wires which do not go to anything else which come from the drivers side of firewall, but are solidly connected (or pinched) behind head.
    Colors: 1. tan-yellow 2. orange 3. gray
    Question: What are the colors for the three wires which go into the 6.5TD oil pressure/fuel pump SWITCH (behind drivers side 6.5 head)?
    Wayne
    Jun 2001
    BigStoneGap VA. USA
    most of the chevys I have fooled with on the oil pressure wiring is a tan color. I'm glad that you have gotten some of the issues worked out on the swap.
    Well,
    I know three wires go to the oil sender switch. One (center) is strictly for oil gage, and two outside are for ground and control for fuel pump. Might control oil pressure too.
    must find a wire chart and find the colors.
    Wayne
    Chevy Cummins MILEAGE UPDATE:
    Trip towing trailer from Fayetteville, NC to Knoxville, TN, pickup Ford 4000 4WD tractor. (17.46 MPG)
    Trip (one way) towing 13K RV (I-95) Fayetteville NC to Aberdeen Proving Grounds, MD (13.1 MPG)
    Both trips (now that fuel hose collaspe problem mentioned in above post fixed) truck pulled on each speed chose on cruise control, with both loads--without any drop in speed on hills. If I started the hill at 55, it finished at that speed or higher, or if I started at 65 or 68 on cruise, it would finish at that speed or faster. Could accellerate on any hill. Could pull 70 or faster, the same.
    Temperature was a constant 150. Could pull in a rest-stop and engine basically cool. Pyrometer never got over 550 (measured 10" down pipe) on any pull (same as 6.5L Banks setup). This is a little cooler exhaust temps than the 6.5L 300HP engine.
    Boost max is 25-37 PSI. (I said 25-30 PSI earlier, but on a long hard pulls with load it stays at 35 or so)
    Pulled off 245-16 Michelin tires and put on 265-16 Michelins.
    Cummins runs pretty good.
    Glad I put it in.
    Wayne
    [ 08-26-2004, 04:20 AM: Message edited by: DogDiesel ]
    Sep 2003
    Feeniks, Aridzona
    We need pics.
    Also, where did you go for motor mounts, trans adapters, etc... We need details!
    MTTwister Guest
    "Well,
    must find a wire chart and find the colors."
    Those are the 3 - Orange +12v, Grey power to the lift pump, and via the 'pump relay' on glow plug cycle., that leaves TAN for gauge, I'd guess.
    Search 6.5 on OPS relay
    http://forum.thedieselpage.com/cgi-b...c;f=1;t=006860
    Great conversion - taking orders? [img]smile.gif[/img]
    Dec 2000
    Homestead Florida(South of Myammi)
    Question
    Hello DogDiesel. Nice conversion! I'm in the middle of a similar one--1989 GMC 1/2 ton with '90 6BT Cummins/TH 400. Any chance you could give me a line on the alternator one wire conversion kit. It looks like a pita to adapt the Dodge regulator to the chevy/GMC wiring. TIA.
    Kirk
    <B>Member# 5723</B><P><A HREF=\"http://www.picturetrail.com/spankster\" TARGET=_blank>PICTURES</A><P>Onyx Black, Graphite Leather, All the goodies! \'01 cc D/A LS 2wd order # Since 02/19 TPW 3/19 VIN 3/20<BR><B>Arrived 03/29</B> <P><B>DRIVING IT</B>
    Lightbulb
    Blacktruck,
    I took my Nippon Denso "Dodge" 140 amp alternator to my local repair rebuild shop. He installed a very large chip right in the back, with wires which made the thing look like a SPIDER. Thats what he said when I walked in, "Oh you want a spider.."
    One hot wire, one field, and she charges perfect. Gage stays between 13.6 - 14.3 no matter what.
    Sorry for the delay, I've been traveling.
    Wayne
    Fan pulley problem.
    Returning from NJ on the 295 NJ turnpike, crossing the Delaware Bridge when tachometer (runs off alternator) quit and the coolant low warning light (plugs into radiator) came on. Pressed in the clutch, coasted up the Delaware bridge, and down into the right parking lot. Got out, and found my serpentine belt ate up and the fan pulley, made of aluminum just melted. The belt had knocked the wire off the radiator. Melted! I've never seen anything like it. The Flexilite fan is still mounted and bolts tight.
    Cut the belt off, removed the fan and pulley and Turnpike assistance came over. Drove it accross what--a dozen lanes of traffic, and parked it in the tollgate parking lot. Lots of parking area lights.
    Gave me a ride to the airport and I picked up a rental. Began looking for parts.
    Problem: Since I took my pulley with me, or the donut of what is left, when I looked at the new OEM pulley ( in Lancaster PA) I realized my fan setup was not OEM. I already knew I had a NAPA belt that was not OEM. Ultimately, I drove back to Philidelphia to pick up a fan pulley bearing mount assembly, had a new OEM belt I had picked up in Aberdeen, Maryland, where my RV was parked, so the next day, I'm putting it back together. Everything went together like new. Engine temps stayed at 150 with no fan. You could touch the engine and the radiator was warm. Oil level clean and constant. I'm back in NC now.
    I already had a Flexilite 418 fan, a solid full time unit, so with the new pulley and mount assembly, I needed a spacer mount assy for the fan setup. Called Flexilite 1-800-851-1510 and Bob the tech guy said Summit Racing has the Flexilite FLX 852 mount, for the reverse 30MM 1.5 thread mount, a steel unit. ($40.39) Ordered it and shipped to my house in NC. Bought six 6mm 1.0 thread screws and washers, mounted the pulley and drove to NC.
    Have yet to mount the fan, but I'm optimistic it will all work. Has too, I tow my Gooseneck trailer back to MD for a NJ pickup of a Allis Chalmers HD-5G crawler for 8 tons of good parts.
    Engine runs excellent. Mileage is about 18 empty with 4.10 gears. 70MPH is 2100 and I have yet to run it long above that. Loves 55-65. Best Cruise control I have ever had on any vehicle. I have cars follow me and set their cruise because I guess my cruise is constant and I open traffic so they can mindlessly drive.
    Suspension handles the Cummins great, truck drives like it did with the 6.5L. I doesn't feel as "sporty" with the Cummins basically because I have less RPM. That 6.5 300HP will run circles around the cummins while it pulled good too. But this Cummins pulls any speed and gets down and pulls with the exhaust sounding like an 18 wheeler on hard pulls, the cruise holds with load. Grunts and keeps pulling. No matter the speed at hillstart, thats the speed you crest the pull with or faster. Damn nice.
    Almost every day, I have someone ask me "what engine do you have under the hood. I know that ain't no Chevy or Duramax?" It gets a lot of smiles and makes for a conversation starter.
    But the turbo whine and exhaust note when pulling is loud. I'm running the 4" WarpSpeed system, and it muffles little on hard pulls. A convertible corvette in the RH lane with two girlymen let me know it was loud, they put their figers in their ears, so I tapped the throttle and gave them a goodbye.
    Thanks for the answers on Oil sender wires. Carey Weber sent me a wire diagram, and it matches the three mystery wires I found.
    Guys, I have pictures, with intent to make a Chevy Cummins conversion website. Will layout details and notes.
    Thanks.
    Wayne
    jspringator Guest
    I can't wait to see your website! Mine has 173,000 miles. I am trying to plan my repower in advance, knowing failure is likely to happen far away from home at a very bad time. My options are a 6.5 with a new AM general block, a Duramax, with or without Allison conversion, and a Cummins conversion, with a rebuilt Jet 4L80E. It looks like the Cummins conversion would be at least as easy as the Duramax, and substantially cheaper, due to the ready availibility of used Cummins engines. However, I will need a "cookbook" with parts listed for my year (99) so I could get a shop to do it. I know I will need a standalone computer for my transmission. Otherwise, can this successfully be done on a 99?
    Dec 2000
    Thumbs up
    Thanks for the "Spider" tip. Looking forward to the pictures and build info. These 'lil 5.9's got some grunt
    Kirk
    Wink
    The Flexilite fan mount adapter came in from Summit Racing (2 day delivery).
    Bought 4 8mm 1.25 x 50mm bolts, some 5/16" flat washers and mounted the fan to the adapter.
    Screw it on (reverse thread). Mounted. Done.
    With this new smaller pulley, the fan speed is slightly faster. Sound does not supercede the 12 valve cummins.
    Fit and function is clean and nice.
    All the pulleys and mounting hardware are now OEM steel. Nice setup.
    Wayne
