Thread: 94 trans not locking up
    Apr 2018
    Roggen
    Default 94 trans not locking up
    I’ve done searches but not coming up with anything.
    94 2500 213k 6.5td. It will lock up once when initially started but if I stop at a stop sign and go it will not again until I shut it off. I am getting a brake on code. Which I’m sure is why it’s not locking but I can’t figure out why. Switch is new, and it doesn’t look like there’s any sort of adjustment on these. Not sure which way to go. I can’t drive it like this, don’t wanna cook the trans. Any ideas?
    Hi
    What is the code you are getting ??? What number ???
    Apr 2018
    Roggen
    Sorry for the delay, I haven’t had time to toss the code reader on. It’s a code 37
    May 2014
    us, ga
    I also had a similar weird problem like yours and it was the 3rd brake light. May be totally different than your issue. I had a wire that burned at the 3rd light housing, and was grounding, causing my trans to act stupid.. Good luck!
    #37 is "Brake switch stuck on"
