Thread: 1976 Dodge M882 1 1/4 ton 6.2 swap
    Dec 2007
    Sunnyside WA
    Default 1976 Dodge M882 1 1/4 ton 6.2 swap
    I have a 1976 dodge M882 that i shortened the frame on that I'm swapping the 318 for a 6.2 litre diesel engine. SM465 transmission and NP205.
    the engine and transmission bolted together Centerforce Clutch also
    another view of the engine with an AC delco oil filter
    Setting the engine in place
    Again
    Truck without the engine
    Overkill
    1976 m882 shortened with a 6.2 diesel, np205 and sm465 and HMMWV tires
    1992 Jeep YJ wrangler (project) plans are: 6.2 diesel engine, SM-465, Np-205, Dana 44 front, Dana 60 rear
    1989 GMC suburban, 6.5 TD, TH400, Np-241, dana 44 front , 14bolt rear with Gov locker.
    1997 Kenworth T800, 3406 Cat 575 HP, 18 speed, 4 speed Aux, 3.73 rears
    1986 K30 M1008 6.2 diesel th400 np208 4.56 gears dana 60 front and 14 blt rear
    N/A? = Non-Aspirated? Not Available? Needs Air?
    ΜΟΛΩΝ ΛΑΒΕ
    Are you using the Dodge frame crossover for the engine mounting? I've heard from others who installed a GM frame crossover to get the engine mounting.
    Cool project! Keep up posted.
    Dec 2007
    Sunnyside WA
    im gonna try and use the dodge crossmember
    ΜΟΛΩΝ ΛΑΒΕ
    Dec 2007
    Sunnyside WA
    i was able to use the dodge crossmember, and i made the motor mounts today i will take pics in bit
    ΜΟΛΩΝ ΛΑΒΕ
