OK, it seams complicated, but it isn't.
95 GMC Suburban. 267 thousand miles.
I drove to work this morning, parked the 'burb. Came out to run some errands over the lunch hour and my key won't work in the ignition.
It won't turn at all.
I tried to wiggle the steering wheel, jiggle the key, no luck.
The key is the original one I got and it is worn.
Question is, is it more likely that the worn key just got to a point that it won't engage the tumblers, or is it more likely that the sterring column locking mechanism is broken?
Next step is to try one of our spare keys, but they were cut using the original key.
Second step would be to have a GM shop use the VIN # to cut a new key. Hopefully that is as bad as it gets. If a new mechanism is needed it could cost in excess of $500.
Any other possible causes or suggestions?
Thanks,
forbey
