Thread: duallie question
    Oct 2006
    new brunswick
    Default duallie question
    I was thinking about going from a dually truck set up to singles. is this a possibility. what rims or changes would I have to make
    2005 gmc 3500 c/c 4x4 dually 2015 Sierra 377FLIK 14,000lbs
    Rebuilt Allison w/ billet torque converter and upgraded clutches
    lly Duramax
    edge juice w/attitude
    Kennedy boost stick
    banks air box
    MBRP 4" SS
    egr blocker plate and finger stick
    head studs
    It should be simple to convert to singles.
    Are you changing all 4 ?
    The fronts have off set spacers you unbolt from the hubs
    The rears should be no problem,going the other way is the issue as usually the brake drums on SRW are to big for the daully wheel to go over.
    The rear end on a daully is wider if you have a pickup box on the truck,there is a dually up here that has a high performance engine in it,it's lowered and has wide singles on the back and looks OK
    Oct 2006
    new brunswick
    was planning on changing front and rear dually the mud. was looking at Rickson rims. figure to call and check with them
    lly Duramax
    Kennedy boost stick
    banks air box
    MBRP 4" SS
    head studs
