Results 1 to 5 of 5
Thread: Lift pump wiring
    Feb 2014
    NC
    Default Lift pump wiring
    In the process of replacing the injection pump I had to cut a wire that was spliced into the FSS. Turns out it was for the lift pump. Anyone have a diagram so I can wire it properly.
    Might be helpful if you post the year and model.
    Feb 2014
    NC
    Thought it was in my sig. 1995 chevy k3500 6.5 diesel
    Quote Originally Posted by snarl View Post
    Your sig is not showing....
    You have to check the box under "miscellaneous options" that says "Show your signature".
    Dec 2009
    In the North
    Wire for lift pump from FSS?
    1999 chev suburban C2500
    300,000 mi
  1. 6.5 dieing constantly
    By Jordie.fooks in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-09-2015, 11:54
  2. New rebuild #4 misfire
    By Ooowillow in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-15-2014, 14:02
  3. Question on lift pump pressure- COLD
    By chessy56 in forum Duramax 6600
    Last Post: 12-11-2013, 12:48
  4. Lift pump for the Deep North
    By KingNuzz in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-16-2009, 20:45
  5. Please help re: lift pump and leaky line
    By BWT95K2500 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-02-2006, 20:31
